Author Topic: CB and Ham Radio Techs Love Their Bird Wattmeters  (Read 222660 times)
Offline A.Z.
Re: CB and Ham Radio Techs Love Their Bird Wattmeters
« Reply #1425 on: November 07, 2023, 07:11:51 am »
what about using something like these
https://www.amazon.com/MAGXCENE-Neodymium-Magnets-Countersunk-Storage/dp/B0B48YWRCL
as feet for the box, those should keep it in place as long as it's on a metal surface
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #1426 on: November 07, 2023, 01:00:38 pm »
Well ...
They of course would work to hold anything metal (steel) to themselves. However, I have not a single table that has a metal top. I don't think I have ever had a table like that.
Further, they are neodymium magnets. I have some of those and they are very strong, ridiculously strong. That seller even has a picture that shows the unsuspecting person how to properly separate the magnets from each other. They would hold heavy items up on a wall as in that picture (I'll get to that pic they show in a second). But I suspect letting the magnets attract large objects like solid steel tools would ruin them in short order due to the metal banging against the magnet when the tool gets within a very short distance - you won't be able to stop that. Some people who bought them even uploaded pics of the damaged magnets because they are strong but delicate.
 :o
If they were used as feet, say four feet, on a small project box the box would most likely stay put on a steel table top. But good luck in picking the box up off the table. You won't be doing that. You'll have to slide it off the table if you have to remove it.
Now the picture ... that picture they show (attached) is totally bogus. It's a photoshopped image. Look at the size of the key compared to a hammer or shovel - it's gigantic.
 :-DD
Oh and the shovel - it won't be hanging from a magnet like that. Well unless the magnet is some kind of advanced material discovered from alien UFO technology in area 51 that attracts plastic. I have tools like that and they all come with plastic handles nowadays. But put the shovel blade on the magnet - yea that would work - but it will start cracking the magnet every time it gets close because it will slam hard into it (see above comments).
Offline A.Z.
« Reply #1427 on: November 07, 2023, 07:12:27 pm »
well, you don't need to buy them, if you have a bunch of old HDDs around just open them, you'll obtain a bunch of neodymium magnets, but then they'll be in some unsuitable shape; as for those items, they were an example in case you decided to seem stupid; anyhow, the "metal" surface "issue" and the "detach" one are easily solved with a microgram of gray matter, I did and I've none; so you will probably do better, then regarding the pics, I "suppose" you know about that stuff but then, and again, it's probably all due to my lack of gray matter, will need to seek amazon and see who sells it :P
Offline joeqsmithTopic starter
« Reply #1428 on: November 09, 2023, 01:57:03 pm »
Before attempting to improve that Chinese Nissei meter, I thought I would find some other crap CB/hamster meters to compare with it.  I only have that old Mars VSWR meter which doesn't display Watts.
This was the first junker.  I do mean junker.  Looking at the coupler's performance, like the Nissei, I don't see how this would ever do much of anything.  After seeing this, no wonder the CB/hamster's looked to the Bird as the gold standard.
Offline xrunner
« Reply #1429 on: November 09, 2023, 02:49:33 pm »
Yea, remember I was going to convert that Daiwa SWR/PWR meter to a digital readout just for fun. But when I started looking at the construction of the coupler, I decided not to waste my time on a piece of junk.
Well, some people will still say I'm wasting time but at least it's something that has some quality associated with it.  :-DD
What I need to do now, since I have all the case parts designed and printed, is to add the copper tape shielding before I forget about it. Eh, it's not the funnest thing to do but is has to be done.  :-\
« Reply #1430 on: November 10, 2023, 01:24:13 am »
I could ditch everything but the case and meters.  Put a new coupler and PIC in there with a few of the LOG amps.  Then drive the meters from the PIC.   :-DD
Offline xrunner
« Reply #1431 on: November 10, 2023, 02:06:49 am »
That is a really great way to make use of those parts and I'm looking forward to your progress on that idea.  ;D
One of my goals here is to keep this thread you started in the top three on this board in terms of views. Between you and I we have the top three threads on this board in terms of views -
joeqsmith: NanoVNA Custom Software 423440 Views
xrunner: Whatever Happened to Ham Radio? 245399 Views
joeqsmith: CB and Ham Radio Techs Love Their Bird Wattmeters 143798 Views
Hey nobody can say were not good at anything.  :-DD
« Reply #1432 on: November 10, 2023, 03:12:03 am »
Manual I found didn't have a schematic so I traced out the hamster wheel.  It's crude.  Makes the cheap Radio Shack  meter look high tech.   Guessing this thing was targeted for the CBer with a large linear, as they talk about it being factory calibrated at 27MHz.  They make no claims about accuracy, or even the range it could be used.   I did find an ad where they claim 220MHz.   Maybe they consider if the meters have any response, good enough.
Still, seems symmetrical and guessing that the VSWR and modulation may have worked alright for what it is.  Power for the 160-6M bands, no way.
Offline xrunner
« Reply #1433 on: November 11, 2023, 12:42:09 am »
Before the copper tape is applied I decided to glue the risers to the bottom half of the case. That will make it a lot easier and they really don't need to come off again from there.
The glue I used is SciGrip 16, which will glue PLA and styrene together. If you're a glue-sniffing addict, this stuff would be your dream drug of choice.
*** BONUS PIC ***
I read some reviews and decided to buy a Pinecil mini soldering iron. It isn't for large jobs but I really like it so far. It comes with a conical tip which I don't prefer so I ordered a few more tips to try. I'm powering it from an old 20V laptop supply brick and had to put on a temporary power plug since I didn't have any 5.5 x 2.5 spare solder plugs (on order). It can also be powered from USB C power delivery.
It has a 144 MHz 32-bit RV32IMAFC RISC-V SiFive E24 Core CPU which runs firmware called IronOS. When I was a kid I'd never have thought one day my soldering iron would have a processor inside it to make it work.
« Reply #1434 on: November 11, 2023, 05:34:26 pm »
I read some reviews and decided to buy a Pinecil mini soldering iron. ....
I remember an article, maybe EDN, from the early 80's about a king and his toaster.  We all laughed at the nonsence of putting a micro into a toaster.   Google finds a similar story...
https://www.ecb.torontomu.ca/~elf/hack/ktoast.html
Still, I just repaired the in laws toaster, which certainly has a micro.  This is what my family believes I do for a living, repair toasters....  :-DD :-DD
« Reply #1435 on: November 11, 2023, 07:35:34 pm »
When I was looking at the old time meter, the coupling really falls off as you move down in frequency.   At a MHz, I think it was 60dB or more.
I had made some test loads for when I was working on my home made Watt meter.  These are only rated for a couple of Watts.   I started out a 27MHz where the meter is supposed to work and it wasn't sensitive enough to read the reflected signal, even with a VSWR of 4:1.  I think the idea was, what self respecting CBer would only use a few Watts.  This meter supports a kW afterall.  It's not made for the kiddies.   :-DD
They had used all 1N4148s for the detectors.   I picked up some 1N5711s to try and improve the sensitivity.  These one on one tape and they appear all very close.  These were not the 100 for a dollar ones on Amazon.  It did improve it somewhat.  So I tried it with a VSWR of 3, 2 and 1.5 all at 27MHz.   3:1, I would expect would be much closer.  There is no adjustment and I suspect would be good enough.
« Reply #1436 on: November 11, 2023, 07:57:23 pm »
I left the 75 ohm resistor attached (1.5 VSWR) and tied it at 14, 7 and 3MHz.   The signal is just too small, even with the new detector diodes to get a good reading.  I tried to increase the power to the point where the resistor was getting a bit too hot for comfort, but no luck getting a decent reading.   It's certainly not a meter for the HF hamsters.
A working Bird meter would put it to shame.
« Reply #1437 on: November 11, 2023, 08:33:52 pm »
The coupler uses four brass rods to couple to the transmission line (if you want to call it that).  They have two rods for forward and reflect for the VSWR measurement. One to measure  modulation and one to measure power.   Each circuit is isolated.  It is treated like three unique meters with a common transmission line.  Maybe three different designers.  I'm sure there is a story.   :-DD
Using the LiteVNA to look at the impedance with the antenna connection open.  The first dip to 25 ohms is that old UHF connector the ham and CBers like so much.  Then we have the sort of transmission line followed by the last open circuited UHF connector.
« Last Edit: November 12, 2023, 03:22:25 am by joeqsmith »
Offline vk6zgo
« Reply #1438 on: November 11, 2023, 11:53:59 pm »
Many years ago, I picked up a CB style SWR meter at an establishment calling itself  "Crazy Charlies".
This was in the "returns" tray & was clearly marked faulty.
I thought "might be some useful bits" & picked it up for $A4.00.
I took it home, stuck it on the old 2m "modified taxi radio", & was gratified to see some meter movement.
I took it to work, stuck 8 watts into it from the same radio in line with a Marconi power meter/load & checked the VSWR displayed on the CB meter.
It said, as expected, something around 1.3:1, which was reasonable for something sold as "not working".
Work having an assortment of loads I managed to find a 75 ohm one. The SWR read around 1.6:1- near enough!
It wasn't a "power meter's bootlace" as the "forward power" reading was adjustable to give full scale.
Who cared, as I could borrow the old "Macaroni" one?
From memory, it used OA91 or 1N34 style diodes.
When it came to tuning up 2m antennas, the alternative was to borrow a Grid Dip Meter from work, so it was reasonably useable to "Get in the paddock of where I wanted to be".
Strangely, this particular design of VSWR meter increased in sensitivity at HF, so when I finally got on HF, it was still useful.
Obviously, nothing you would use for work, but ham radio IS just a hobby!
Over time, I have "picked up " several more pretentious CB & even ham SWR meters cheaply, but almost universally the more pretentious, the less likely they were to work.
Finally, the meter failed in the "Crazy Charlies" one & it went in the bits 'n pieces box, but by that time, I had a R-x Noise bridge which was "sorta" useful, & sometimes , access to an MFJ 259.
By dint of not being very active, I went along till I bought a nanoVNA.
Having "short arms & long pockets", I never aspired to possess a Bird.
Offline xrunner
« Reply #1439 on: November 12, 2023, 01:06:50 am »
Yes yes ... you have the "knack". Maybe they don't really realize you became an engineer. Don't tell them at this point in your life, it would be devastating to them.
Offline vk6zgo
« Reply #1440 on: November 12, 2023, 01:39:32 am »
Don't tell my Mother I'm a Technician---she thinks I play the piano in a brothel!
Offline xrunner
« Reply #1441 on: November 12, 2023, 02:23:13 am »
Oh yes, piano player in a brothel is a respectable job - much more respectable than the electronics profession. Let her keep thinking that.  :-+
Offline vk4ffab
« Reply #1442 on: November 12, 2023, 03:34:21 am »
Bird Watts. Is that an SI unit? Or an a this Unit is a Silly Idiot?
Offline metrologist
« Reply #1443 on: November 14, 2023, 09:44:50 pm »
That actually seems pretty good for what it is supposed to be. Not everyone starts riding on a VMAX.  ::)
« Reply #1444 on: November 15, 2023, 12:33:50 am »
Looking at the modulation feature of the low end hamster wheel,  if I align the meter at 27MHz and 99% modulation, it is a way off at 20%.  Aligning it at 80% modulation gets things in the ballpark, sort of.
« Last Edit: November 15, 2023, 12:37:59 am by joeqsmith »
« Reply #1445 on: November 15, 2023, 12:37:12 am »
If I increase the frequency to 140MHz and use 30% modulation, the meter reads nothing.  SWR on the other hand works reasonable as I would have guessed.
« Reply #1446 on: November 15, 2023, 12:43:51 am »
I thought I would try the SWR at with a bit more power at 3MHz to see if we could get enough signal to get a decent reading.  I have no idea how much power I was putting into that poor little mismatched load but melted the hot glue pretty quickly.   With 25ohms, or 2:1 VSWR, meter appears accurate even at 3MHz.
So, I think for the hammers running 50MHz and below, the SWR and modulation features may have been alright but power.....  Let me try a sweep and see just how bad this thing is.
Offline xrunner
« Reply #1447 on: November 15, 2023, 01:32:31 am »
Well you're having a lot more fun than I am.
No more plastic cases for this class of project.  :scared:
Progress continuing ...
« Reply #1448 on: November 15, 2023, 02:01:15 am »
I like using PCB material for cheap and dirty cases.   Instant shield.
Using my RS meter & attenuator, which was verified using calibrated equipment last year, I aligned the hamster wheel at 27MHz in the three different ranges.  I then took measurements with 5 & 20W applied, at 3,7,14 and 50MHz.   Yes, you are reading that right, with 5Watts @ 3MHz applied, the meter reads 300mW!   :-DD :-DD  All hail the Bird!
Does make me wonder if I bought a new analog meter from MJF or such, would it be any better.  Hard to believe it could be much worse.  Then again, even that cheap Chinese Nisse RS-70 isn't looking so bad now.   :-DD
« Reply #1449 on: November 15, 2023, 02:11:04 am »
MJF267
https://www2.randl.com/index.php?main_page=product_info&cPath=17_14100&products_id=36750
High accuracy comes from a carefully designed directional coupler, an accurate active-peak reading circuit and a precision d'Arsonval meter movement.
I know this is where I spent all my time (coupler directivity and flatness)...
Reads true peak PEP or average power on 300/3000 Watts forward and 60/600 Watts reflected power ranges 1.8-54 MHz.
Covers roughly the same range as my homemade meter and that Nissei.
