Yea I'm still working on it ...
![Tongue :P](https://www.eevblog.com/forum/Smileys/default/tongue.gif)
I got the top plate mostly done. This is where the Due board sits - on top of three stand-offs coming up from below where the RF parts are located. The top plate has slots where the mounting hardware goes through. This is so it can be pressed up exactly to the back of the rear case panel.
There are three mounting holes in my plate for the Due board, and the plan is to use M3 brass inserts in them for the bolts to go into. But why only three bolts - aren't there more mounting holes in the Due board than that?
Yes there are - six total. They are sized for M3 hardware. But I really don't need to use all the holes for one thing. The other thing is - there is not enough clearance on more than one screw hole for the head of the bolt. It will not go past the header. I have seen this before on the Uno boards and as well on the new R4 Minima boards. I do not know why they put some of these holes so close to other parts. I suppose greater minds than mine know why.
I ordered some new PLA from Atomic filament. I'm going for a certain color scheme. The original case is gray. I have a yellow OLED display. So I thought I'd have the other case parts black. They have a new type of black PLA filament that is more, uh, blacker-er than the previous black -
The darkest, most true tone black filament. 6 months in development with our color supplier, an extremely pure black colorant with no off shades of grey, not carbon black based. Full synthetic color formulation.
Extreme JET BLACK filament
Maybe you thought black was a simple thing?
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
