Author Topic: CB and Ham Radio Techs Love Their Bird Wattmeters  (Read 216201 times)
Online Kosmic
Re: CB and Ham Radio Techs Love Their Bird Wattmeters
« Reply #1025 on: February 03, 2023, 12:02:27 am »
I wonder if those HT antennas are monopole. If it's the case then the ground plane would be in the device and thus not included in the test when connected to a NanoVNA. Might explain the bad results when testing the antenna alone.
Now is the ground plane really useful for transmission ? i'm not sure.
« Last Edit: February 03, 2023, 12:06:17 am by Kosmic »
Online joeqsmithTopic starter
« Reply #1026 on: February 03, 2023, 06:48:24 pm »
Ham using "science" to compare some antennas.  At first, I thought oh no, here we go again.  Then he surprised me by actually taking  them on a road trip and puts them to use at  2 & 4miles.   He talks about the few who live in their scientific bathtub with their NanoVNA toward the end and cries BS.
I think if I were reviewing hand held radio antennas, this is exactly what I would do or at least it would be a big part of the evaluation.
If I were trying to show someone how to construct antennas and trim them,  most likely I would have some sort of bridge in my bathtub as a starting point.
https://youtu.be/k-fkcgpGuOM?t=837
Offline vk6zgo
« Reply #1027 on: February 04, 2023, 03:24:25 am »
Certainly a nanoVNA, or some sort of bridge is something I like to include in my "bathtub", to at least know what the antenna "looks like" to the source.
Other characteristics are dependent on a whole raft of other things, so measuring the received signal level at a "remote" point is definitely a good idea, at least for VHF/UHF stuff, especially antennas on handheld radios.
It gets a bit messy with HF, where the desired angle of elevation of the radiated signal might mean that much of the signal is not well received at a relatively close "remote" point, & the azimuth pattern is also different at ground level.
I was initially surprised that his signal drops out at around 4 miles, but looking at the topography around his station, I can see why.
I have definitely done better with handhelds where I live, but, although looking down from the Darling Escarpment, the coastal plain
looks "as flat as a pancake", up close, there are many high points which help a lot.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #1028 on: March 04, 2023, 01:52:09 am »
Bird 43 rackmount. If you want Big Iron here it is. Carrier / Sideband using two slugs.
The following users thanked this post: TheSteve
Offline Chat GPT
« Reply #1029 on: March 10, 2023, 10:46:09 am »
Bird watt meters have been a trusted and reliable tool for measuring RF power for many decades, particularly in the CB and ham radio communities. They are known for their accuracy, durability, and ease of use. While there are now many other brands of watt meters available, Bird remains a popular choice among many RF professionals and enthusiasts.
Online xrunner
« Reply #1030 on: March 10, 2023, 11:58:23 am »
You say they are known for their accuracy, but you didn't say what the accuracy was, or which Bird wattmeter you were claiming was known for this accuracy. Can you tell us these figures if you know them?
« Reply #1031 on: March 11, 2023, 06:44:59 pm »
 :-DD :-DD  No ones going to touch that one!
Offline metrologist
« Reply #1032 on: March 15, 2023, 03:03:04 pm »
The Bird 43 wattmeter was released more than 70 years ago. What else were you going to use back then?
Power Range: 100 mW to 10 kW (using Bird® Plug-in Elements)
Frequency Range: 450 kHz to 2.7 GHz (depending on element)
Insertion VSWR: 1.05 max. to 1000 MHz (with N Connectors)
Accuracy: ±5% of full scale
https://birdrf.com/Products/Test%20and%20Measurement.aspx
Online xrunner
« Reply #1033 on: March 15, 2023, 10:05:25 pm »
70 years ago? That's exactly what I would use ... 70 years ago.  ::)
Yea I am very aware of those specs - what I wanted to know was if the entity posting, now known as Chat GPT, (and banned) knew it. That account was another name until the mods found out and renamed it to Chat GPT because that's where the text came from (unattributed to ChatGPT). But of course they never responded because they were too lazy to even ask ChatGPT for the specs. The account also made other posts on this forum that came from ChatGPT. That's the point of me asking them what the accuracy was. There are accounts being made here that are simply making posts that come out of ChatGPT and it's going to become an increasing issue in the months and years ahead.
« Last Edit: March 15, 2023, 11:44:15 pm by xrunner »
Offline vk6zgo
« Reply #1034 on: March 16, 2023, 12:24:48 am »
The big feature of Bird Wattmeters is not absolute accuracy, but rather repeatability.
In commercial use, I have mainly seen them in use as in-line indicators in installations where the original tests would have been done with much more accurate (& expensive) equipment.
The Bird Wattmeter was then placed permanently in line, & its readings recorded.
If it is reading high or low by a particular amount, it is very likely to still have the very same error in 20/30 years' time.
A Tech can visit a site, quickly check the reading on the "Bird", & if it hasn't changed, be reasonably confident that there is nothing amiss.
if it reads differently, it is time to "bring out the big guns".
Ultimately, some of these Wattmeters reach the Amateur Radio market, where they are prized because of repeatability.
Although some of the similar devices built for that market, & indeed, the CB one, offer similar accuracy, they are "built down to a price point" & due to poor mechanical design & bad soldering may fail in a relatively few years.
Of course, you know all this, but no matter how many times you tell it, Chat GPT will never know, as it treats every question as if it was the first time it was asked, & does not learn from interactions.
« Reply #1035 on: March 21, 2023, 01:22:53 pm »
Saw what appears to be a vintage Bird for sale.
https://chambana.craigslist.org/ele/d/georgetown-watt-meter/7600931469.html
Online xrunner
« Reply #1036 on: March 21, 2023, 09:11:10 pm »
Yea may be vintage.
But wait ... I see a Coaxial Dynamics slug in that thing. Isn't that considered blasphemy?  :-DD
Offline vk6zgo
« Reply #1037 on: March 22, 2023, 02:05:33 am »
Yea may be vintage.
Nope! They are totally compatible, so it is done regularly.
I wonder which is the "clone"?
Offline pienari
« Reply #1038 on: May 16, 2023, 08:27:52 pm »
Meters and meters.
When i started to build rf amplifiers i used several different brand instruments because all was showing different results.
But after i bought digital oscilloscope i made 10:1 sample att to 50ohm ant line.
Today i can make 100% accurate measurements.
Just check voltage and go to
https://www.random-science-tools.com/electronics/dBm-Watts-volts.htm
You will get Average power.
Online xrunner
« Reply #1039 on: May 16, 2023, 08:38:37 pm »
Really?   ::)
« Reply #1040 on: May 17, 2023, 12:09:05 am »
You're such a doubter.    :-DD
Online xrunner
« Reply #1041 on: May 19, 2023, 11:30:24 pm »
Was speaking with a local ham a few days ago about his effort to calibrate a Daiwa cross-needle power/SWR meter. If you don't already know, this type of meter reads forward and reflected power and SWR. By observing where the needles cross, and the markings behind this crossing point on the faceplate, you can read the SWR (approximately).
I said I have one also - a CN-103 (his was a different model) and I'd calibrated it before. We got to talking and he wondered if they could be "converted" to a digital read-out. I said I didn't see why not, but it sounds interesting and I'd think about it as a project.
So I'm thinking about it. I got the schematic and I want to make some measurements of the voltage range that the meter movement is receiving from the detected RF in this Daiwa design. I don't think I'll even need to be worried about the range switch - that is in there because they are using mechanical meter movements.
Also, if I do it, I'd want it to be 100% accurate too.  :-DD
« Reply #1042 on: May 20, 2023, 03:53:38 pm »
Is Daiwa in Japanese spittoon?
Online xrunner
« Reply #1043 on: May 20, 2023, 04:50:31 pm »
They're into sport fishing now it seems -
https://daiwa.us/
« Reply #1044 on: May 20, 2023, 06:22:00 pm »
Looks more like chewing tobacco than lake water.
Online xrunner
« Reply #1045 on: May 20, 2023, 06:41:15 pm »
Any and all dried fluids and scratches will be attributed to my cat.  :-DD
« Reply #1046 on: May 20, 2023, 09:01:42 pm »
Fish, pussies and dribble.   Are we back on BD139's floozies or Watt meters?
Online xrunner
« Reply #1047 on: May 20, 2023, 10:12:41 pm »
Wherever you want to go - I'm busy answering your inquiries about spittoons and lake water.  :-DD
« Reply #1048 on: May 21, 2023, 12:23:47 am »
Is your friend with the Bird planning to have you add digital to their meter as well?
Keep thinking I should get some sort of high end hamish Watt meter and do some sort of shoot out with it.
Maybe something like this:
https://static.dxengineering.com/global/images/instructions/mwr-fx775-fx3.pdf
With the PC interface, we could compare screen update rates.
« Last Edit: May 21, 2023, 12:44:05 am by joeqsmith »
Offline seedkey
« Reply #1049 on: May 23, 2023, 04:36:22 am »
Dem are bird watts
