Is the plan to still build the second one? Assuming you are happy with the performance of this one?
Probably. I can use lessons learned and suggestions from this version for the next one such as what A.Z. said -
use the macaws squawks and the chair creaks as "high SWR" and "overload" alert sounds in the meter ![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
I can incorporate the Macaw screams like this -
"Hey xrunner that pwr/swr meter you built me was screaming bloody murder at me yesterday, what does it mean?"
![WTF? :wtf:](https://www.eevblog.com/forum/Smileys/default/wtf2.gif)
"Oh that? Yea it means one of two things:
A. The meter is lonely because it misses you and it's screaming out for your attention. Go to it and pet it until it stops.
or
B. Your system SWR is above 3.0, investigate the problem and check until it stops screaming"
"Thanks xrunner it sure is a sweet meter!"
When do we get to see the new face plate?
Soon. I need to get to work on them next.
Here's what I need to do:
1. Design front and rear faceplates in Fusion 360 and 3D print
2. Get it all wired up.
3. Make a couple of jumpers to connect RF in and out of the directional coupler to the rear SO-239s
4. Put copper tape on the inside and get it all to connect to ground
5. Test and re-measure levels to get new correction factors for the four bands
6. As far as the software goes, the pwr and swr equations and band selection already works correctly. But I want to spend time on the display presentation and graphics. Fiddling with different fonts and things like a bar graph, placement, etc. takes a long time to get it right. There's just no simple way to do it other than make a change, recompile, and look at what you just did on the actual display.
