If it's running with a high enough feedback ratio and load impedance, the amplitude will be limited by Vce(sat), which has little tempco.
If it's running with a lower load impedance, it might be limited by Vbe instead, which would be a bit of a problem.
It doesn't strike me as a precision device, not one that can be expected to hold constant with respect to temperature.
