Hi all,im not sure if this should be here or in the repair section,here goes anyway,the tx/rx relay went intermitent on rx,i found one in an old cb amp i had so wired that up using short bits of coax,see pic,ever since ive noticed the radio seems to have birdies on most bands that read about s3,thats without my antenna connected,on the bits of coax i used i only grounded the relay end of the cable shield,not both ends,could this be causing this issue?,cheers m3vuv
