Thank you very much. Now the LOCKDETECT test on my board is passed and the output is high, but there is still no signal output. There is a new program document below, some register parameters have been changed, and my simpll design, my circuit design and evaluation The version seems to be only a few decoupling capacitors different, will it cause a big impact?
