https://ieeexplore.ieee.org/stamp/stamp.jsp?arnumber=8012467Has anyone looked at fractal 3d antennas before? I guess planar fractal antennas are not as interesting as this.
It seems that that antenna reminds me of a fractal discone. I am thinking a fractal biconical antenna would do something as well. This would be a fascinating use of 3d printing and metal casting IMO.
It does look difficult to cast however, the metal used would need to have a very high flow and it would need to be die cast (hard) or maybe vacuum poured.
But I don't think there is anything preventing anyone from cutting a whole bunch of pyramids out by hand and soldering/brazing them together in a fixture.. it would just require the use of heat sink putty to prevent the previous bonds from desoldering themselves. Might get quite tricky to solder that by hand.
