Loading [MathJax]/extensions/Safe.js
Author Topic: Amplifier which can take a DDS signal to 5watts?  (Read 4196 times)
Offline PlasmateurTopic starter
« on: May 21, 2017, 02:19:15 am »
Hello,
I'm trying to amplify a signal (2-30MHz) from my SDG2042X function generator. I need  5watts(37dBm) so  I can drive the TC-300 amplifier.
The signal generator I'm using can only achieve 5Vpp into 50Ohms at the frequencies of interest - so about 60mW (18dBm)
I've tried searching  the internet to see if such an amplifier exists. I believe I've only found onehere, but it appears to generate some high 2nd and 3rd harmonics in the signal according to the pictures which are posted.
Ultimately I will want to do the following.
1. Signal generator
2. Amplifier to 5W
3. Amplifier to 150W
4. Matching network
5. Digital SWR meter
6. Antenna
Does such an amplifier exist commercially or will this need to be built by myself?
« Last Edit: May 21, 2017, 04:42:38 am by Plasmateur »
Re: Amplifier which can take a DDS signal to 5watts?
« Reply #1 on: May 21, 2017, 04:40:38 am »
PS You said "antenna" ... do you really mean for communications?  Or according to your handle is this for some kind of RF plasma industrial / scientific / whatever thing?
If so can you just shield the device to cut down on unintentional radiation by 10-20dB or something (yes not exactly easy / cheap for devices a lot bigger than a PC chassis then again 30MHz is a low frequency so even coarse wire mesh is so much less than the free space wavelength that it might help screening quite a lot even without a full on screened room.
Most plasma science / industrial stuff I know of is usually confied to ISM bands which helps and something like NMR and its gradient coils is used in screened / shielded rooms anyway.
Yes. This is for plasma production and scientific purposes. I would like to be able to produce a plasma with something other than a clean 13.56MHz or 27.12MHz sinusoidal wave. I would like to do some kind of amplitude modulation.
The Faraday shielding will be taken care of. The copper can be found pretty cheap off McMaster-Carr.
With that said, I have ALOT to take in with your first post and all of your suggestions. Thank you for the information!
As for the LZY-22+....we have one of those in the lab! Unfortunately it is way outside of my personal price range. Hahaha. Otherwise I would love to use it.
After doing a little more digging online I've found that people are driving the TC-300 under 3watts.
So I think this device might be able to do the trick for me.
Offline G0MJW
  • Mike
    • G0MJW
« Reply #2 on: May 21, 2017, 08:25:40 am »
Firstly - there is a good reason why certain frequencies are used for industrial/scientific/medical purposes. It is very difficult to not inadvertently radiate RF and cause interference to other users. Screening it will help but don't underestimate just how difficult this can be. Its important to keep away from especially sensitive frequencies.
A potential solution for you is to use some of the more modern 50V LDMOS RF power transistors in a broadband transformer coupled circuit. These devices are quite costly but designed to be very robust to output miss-match - which I expect will be the case. Their inputs are very sensitive to overdrive, but also very sensitive so you only need 1W of drive and probably less. Its easy to generate 1W at 2-30MHz and there are loads of circuits and kits about. The high power stuff is basically the same as an amateur HF broadband amplifier like W6PQL produces.
You might want to look at this site https://www.qrp-labs.com/ While their ultimate 3S kit seems nothing like what you want, it actually is pretty close and would just need you to write different code for its microcontoller,  use the arduino shield, or ditch that board and adapt whatever it is you are already planning to use. There are filters and power amplifiers up to a few watts.
Mike
Mike
Offline G0HZU
« Reply #3 on: May 21, 2017, 07:12:21 pm »
If you don't mind buying old/used gear then the (very old) Marconi TF2167 50kHz-80MHz 10W amplifier would be OK for this. However, it can be tricky to find a fully working example these days.
The good news is that they are usually quite cheap, I bought one last year for £40 and once I'd fixed the PSU inside it works fine. A fully working one might be £150. However, your TC300 150W CB amplifier looks like it will be quite dirty. I'd expect the odd order harmonics to be -15dBc or worse at full power from the TC300 if there is no LPF after it? So the low distortion in the TF2167 will be wasted if you feed it to that CB amplifier. At 5W output I'd expect the harmonics from a typical TF2167 to be much lower than this.
« Last Edit: May 21, 2017, 07:18:00 pm by G0HZU »
Offline tautech
« Reply #4 on: May 21, 2017, 08:08:03 pm »
Hello,
1. Signal generator
2. Amplifier to 5W
4. Matching network
6. Antenna
Yes.
It's an accessory for Siglent AWG's.
SPA1010
http://siglentamerica.com/prodcut-fjxx.aspx?fjid=1289&id=1364&tid=16&T=2
Recently mentioned in the SDG2042X thread also:
https://www.eevblog.com/forum/testgear/the-siglent-sdg2042x-thread/msg1205372/#msg1205372
« Last Edit: May 21, 2017, 08:10:27 pm by tautech »
Offline G0HZU
« Reply #5 on: May 21, 2017, 08:41:09 pm »
That SPA1010 looks like it is limited to a 3dB BW of about 1MHz. Probably less if you want to run high power. So I don't think it is going to be a good choice in this case.
Offline G0HZU
« Reply #6 on: May 21, 2017, 08:52:36 pm »
I dug out my old Marconi TF2167 amp and tested it at 5W output across 2-30MHz and the worst case harmonic was the third harmonic and it was -42dBc or better at 5W output at all test frequencies. This is unfiltered at the amplifier output but the sig gen feeding it was filtered to produce a clean driving signal to the TF2167. So the TF2167 was the weak link here and it still managed -42dBc harmonics or better at 5W output.
Offline David Hess
  • DavidH
« Reply #7 on: May 21, 2017, 11:55:20 pm »
What distortion performance is achievable with a modern shunt feedback amplifier over that frequency range and with that power requirement?  I checked some shunt feedback complementary amplifiers used in function generators and they are about 10dB low in power and 20dB low in distortion performance.
I believe some modern wideband no-tune HF push-pull amplifiers could handle it; they manage to meet FCC requirements for output harmonics without changing output filters.  Even better, they use input and output transformers which can be constructed relatively easily using ferrite elements, coaxial cable, and maybe some brass sections.
« Reply #8 on: May 22, 2017, 02:41:51 am »
Hello,
1. Signal generator
2. Amplifier to 5W
4. Matching network
6. Antenna
Yes.
SPA1010
3dB @ 1MHz. Not sure that is going to work. Can I get 5watts @ 30MHz?
If I could send a software trigger to trigger both channels of the SDG2042x AND use this function generator amplifier. Well that would be the bees knees.
Offline CJay
« Reply #9 on: May 22, 2017, 07:03:39 am »
Dump the CB amplifier if you want to use a range of frequencies though, it's be passable if it was on one or two spot frequencies because you'd be able to clean it up but by the time you'd designed and built suitable filtering for your intended range you might as well have saved your time and money to buy/build a better amplifier.
