Author Topic: ADF4351 LCD version missing software - any good soul?  (Read 3122 times)
Offline xardomainTopic starter
« on: December 15, 2021, 05:37:13 pm »
just bought an ADF4351 board (the one with LCD touch) but in the heat of the moment I selected a seller that does not list the software for optionally driving it.
Now, I don't plan to use the software for the application I need (Oscar 100 sat transceiver, to downconvert the LNB into ham frequencies to skip the SDR rx) but I could in the future drive it using a pc.
Since the seller is taking some time to address my request, could any good soul to share the software?
I see that a serial port does show up, and somewhere there is a protocol description but just to not reinvent the wheel...
Hope this does not break any rule, in this case please disregard.
Thanks in advance.
Giuseppe Marullo
IW2JWW - JN45RQ
giuseppe at marullo dot it
Offline ledtester
Re: ADF4351 LCD version missing software - any good soul?
« Reply #1 on: December 15, 2021, 07:00:37 pm »
Have a look at this thread:
https://www.eevblog.com/forum/rf-microwave/how-to-control-ltdz-max2870-23-5-6000mhz-signal-source/
for some pointers to PC software and other tech info.
« Reply #2 on: December 15, 2021, 10:07:14 pm »
Hi Ledtester,
I did already see some posts, but following your suggestion(Thanks!) I re-read them and after some fiddling, this is the link to the software:
https://www.tonyplaza.nl/download/YT054/PLZ-PLL-435X.zip
It seems it is from Tony Albus, found the reference here:
https://techymetrics.com/download/SUf2T9pSD3Y/054-adf4351-lcd-signal-generator-35-4400-mhz-with-sweep
There are other downloads related to ADF451, but I did not test them (yet).
As always, use at your own risk, VirusTotal says ok (2/60 detection rate, no big AV complained)
Thanks again for your suggestion, I would not have looked again there.
Giuseppe Marullo
IW2JWW - JN45RQ
The following users thanked this post: ledtester
Offline ledtester
« Reply #3 on: December 15, 2021, 10:43:07 pm »
Thanks for providing the link to the software you found - I'm sure it will help others!
Offline tonyalbus
    • My Channel
« Reply #4 on: August 04, 2022, 09:20:22 am »
Its save. :)
