Hello,
When adding notch/reject filter by putting them in series, will it work?
Is it as easy as the losses are added and nothing more complicated? It sound a little too easy...
And what about the length of cable between the filters ?
Basicaly, I want to block two annoying signals, that are one each side of my band of interest. Is it good to make a notch/reject filter for each ?
Because if I make a band pass, on UHF, the loss are too big. But the added losses of two reject filters are not a very big. 0.5db + 0.5db it's quite good
By the way, why it's so different ?
Thank you for any advices
Julien
