Author Topic: Adding notch/reject filters in series  (Read 1299 times)
Offline jujunTopic starter
« on: June 20, 2018, 11:11:07 pm »
Hello,
When adding notch/reject filter by putting them in series, will it work?
Is it as easy as the losses are added and nothing more complicated? It sound a little too easy...
And what about the length of cable between the filters ?
Basicaly, I want to block two annoying signals, that are one each side of my band of interest. Is it good to make a notch/reject filter for each ?
Because if I make a band pass, on UHF, the loss are too big. But the added losses of two reject filters are not a very big. 0.5db + 0.5db it's quite good :)
By the way, why it's so different ?
Thank you for any advices :)
Julien
« Last Edit: June 21, 2018, 12:36:43 pm by jujun »
Offline ejeffrey
Re: Adding notch/reject filters in series
« Reply #1 on: June 21, 2018, 01:57:16 pm »
As long as the notches don't overlap it should work fine.  If they overlap there will be a standing wave between the filters and rejection may decrease at some frequencies relative to a single filter.
« Reply #2 on: June 21, 2018, 02:43:45 pm »
Thank you!
So it's wonderful, and it's a lot better than making a band pass!
I will try to make very broad band block filter to see if it's possible to have low losses.
Offline CopperCone
  • *knock knock*
« Reply #3 on: June 21, 2018, 02:54:41 pm »
You can put an isolator between reject filters of the same notch i think
« Reply #4 on: June 21, 2018, 05:00:25 pm »
What is it ?
Online Wolfgang
    • Electronic Projects for Fun
« Reply #5 on: August 15, 2018, 08:40:36 pm »
Tip: You could simulate the circuityou have in mind  using SPICE you have in mind so you can predict the effects.
I notoriously do this, results are OK:
https://electronicprojectsforfun.wordpress.com/rf-module-gallery/the-rf-filter-gallery/
