The delivery man brought a new toy yesterday, a Marconi 2041 "low noise" sig gen:
I stumbled across this on *bay last week for what seemed like a decent price, then made a low-ball offer, which to my surprise was accepted. $600 shipped (plus tax) for a high-quality 2.7-GHz sig gen in working condition. Despite some signs of abuse, it indeed appears to work as advertised.
This thing is built like a tank, and heavy! I intend it to replace its little brother, a Marconi 2022.
I have no test equipment to accurately measure phase noise, only an Agilent 4396B spectrum analyzer, but I was curious what I could learn. First, here is the specified phase-noise performance of the 2041, then the SA:
At 1 GHz, if everything is working as it should (and maybe even if it isn't...), the SA phase noise should dominate at offsets greater than ~ 100 Hz, and indeed that seems to be the case:
There are some close-in spurs at harmonics of 60 Hz. If I look at the SA's 20-MHz calibration output and compare with the 2041 set to 20 MHz, the spurs are visible on both, so I guess this is happening within the SA. First, the 2041 at 20 MHz:
and then the SA cal output:
Does this indicate a problem with my SA, or is it expected?
Finally, comparing the 2022, also at 20 MHz to match the previous two plots, the noise sidebands are comparatively huge:
I looked for a phase-noise plot for the 2022 but couldn't find one. In several places I've read it has "good" phase-noise performance at HF, and this seems fairly horrible, so I'm wondering if my unit has a problem?
