Had the opportunity a while back to take the covers off a variety of Mini-Circuits modules in lab stock. It's pretty standard stuff as far as RF is concerned, so this'll be old hat to most people here, but I'm only tangentially involved in the high-frequency world so I'm still easily impressed by things like special winding patterns on wideband RF chokes.
Many of the older modules contained just a PCB with the metal-can version of the equivalent Mini-Circuits part (which makes perfect sense from keeping design/stocking/production efficient), and one switch module would've been visible only if desoldering the connectors, but there's still some things to see in the rest of them:
ZX60-6013E-S+ wideband ampWas surprised at the small number of components actually - just a single transistor and/or MMIC, DC filtering then a choke and series resistor to bias the output/collector/drain, and DC-blocking caps at the input and output.
![](https://live.staticflickr.com/65535/52732167572_15fc106450_c.jpg)
Also looks like there's a small stub or capacitive bit on the output for matching (the frequency range does extend up to 6 Ghz).
ZFSC-2-1W-S+ splitter![](https://live.staticflickr.com/65535/52732164357_42980aec7e_c.jpg)
Seems to use the common "center-tapped transformer with resistor across it + 2:1 auto-transformer for input impedance matching" scheme (described in more detail here:
https://www.minicircuits.com/app/AN10-006.pdf, but with a little bit extra in the form of some planar spiral inductors (which must have values in the single nH range or below) in series with that resistor across the outputs, and an extra capacitor to ground. If I remember correctly, I think that capacitor to ground partly compensates for the magnetizing inductance of one or both transformers, and the series inductors with the 100Ω resistor compensate for the output transformer's leakage inductance - but can't find a reference on that right now.
U2C-1SP2T-63VH SPDT RF switch![](https://live.staticflickr.com/65535/52733088380_6d75551a72_c.jpg)
![](https://live.staticflickr.com/65535/52732929549_a31f053c1d_c.jpg)
Looks like what's an SPDT switch at a high level actually uses 6 SPDT switch ICs inside. The switch directly on the COM port seems to have been added so that it can be disconnected from both NO & NC and terminated to 50Ω. One of the extra pairs of switches on the NO & NC ports is there to terminate the port to 50Ω when unused (you can see the termination resistors, larger on the ones closer to the port and smaller on the switches one level back from the port), and the second pair I think is to add extra isolation when unused.
Kind of funny in a digitally-controlled model like this (it takes USB, I2C, and SPI inputs) where the microcontroller and power supply just for interpreting inputs has 100x more transistors than are in the RF "business end" of things.
LZY-22+ RF PA![](https://live.staticflickr.com/65535/52733168593_765dd97cbd_c.jpg)
You can see the signal path clearly here, where from the left it goes through a crossed diode pair to protect against input over-voltages, and then 3 gain stages: first a small SOT-89 class-A stage, then a larger heatsink-mount class-A stage, and finally what looks like a class-AB dual-transistor stage to provide the full output power. The 100Ω resistors next to the output transistors seem to be involved in providing some local feedback for the output stage. There's a bunch of stuff around for biasing that I haven't mapped out, regulators etc. The big TO-247 transistor screwed to the case seems to be a voltage regulator for the incoming power, and the "Airpak" device turns out to be a thermal switch for over-temperature protection.
ZFSWHA-1-20+ switchFinally, an amusing example of the "standard Mini-Circuits PCB-mount part within a module":
![](https://live.staticflickr.com/65535/52733177708_b439573982_c.jpg)
I like the hack-ish shield hanging over the board, hand-soldered at the connectors and wire-bonded to the IC package. Looks like someone realized too late that there wasn't enough isolation in the design... (or the enclosure created some kind of resonant mode: would think a square of damping material would be a simpler solution there, but who knows about the details)
