Author Topic: A formula for input matching with a source inductor  (Read 1199 times)
Offline LM21Topic starter
« on: September 15, 2023, 08:36:07 pm »
There is way to get a good noise match of a fet with only a source inductor. Does anybody know where I could find a formula and more info about it?
Offline RFDx
Re: A formula for input matching with a source inductor
« Reply #1 on: September 16, 2023, 06:15:46 am »
John Rogers & Calvin Plett (2003): Radio Frequency Integrated Circuit Design, Artech House, Boston/London.
Chapter 6.3.3 (p163): Input Matching of LNAs for Low Noise.
The following users thanked this post: radiolistener
Offline radiolistener
  • Country: ua
« Reply #2 on: September 18, 2023, 03:44:25 pm »
Radio Frequency Integrated Circuit Design, Second Edition, John W. M. Rogers Calvin Plett, 2010 ARTECH HOUSE
page 191: 7.3.4 Input Matching of LNAs for Low Noise
« Reply #3 on: September 18, 2023, 05:49:32 pm »
Thank  you both. Now I don't have to  visit university Library.
« Reply #4 on: September 18, 2023, 06:04:19 pm »
At a quick read I see that this book uses ICs as even its name says. Things are different when you cant spread the fet gate, I'll buy a fet or bipolar. (Or I 'll use a low noise RFIC.) Do you know is there enough info here to use ontheself transistors.
Offline RFDx
« Reply #5 on: September 18, 2023, 11:54:18 pm »
You can use any off the shelf transistor(s) you like. Attached are two simple examples, 2m RF preamps with 50 Ohm I/O. The first preamp with a BFR106 (@5V/25mA) BJT and the second with J309 JFETs in cascode configuration, both not optimized for lowest possible noise.
