Author Topic: Troubles with Colpitts Oscillator  (Read 2827 times)
Offline fnpfarTopic starter
« on: July 14, 2016, 05:21:08 pm »
Hello. I´m trying to build a colpitts oscillator to use as a local osc. for various projects.
I build this schematic, but when powered, it doesnt work, only the transistor heats up, and the voltage on the base remains near 0v, despite I have added a potentiometer to add bias.
What is wrong with it? I tested it with various combinations of coils and capacitors, but It doesnt oscillate.
Thank you for your help!!
Offline Tom45
Re: Troubles with Colpitts Oscillator
« Reply #1 on: July 14, 2016, 05:38:17 pm »
Shouldn't you have an inductor where you have the 1K resistor?
« Reply #2 on: July 14, 2016, 06:01:47 pm »
But without this limiting resistor current would flow through the transistor burning it.. i think (?)
Offline Tom45
« Reply #3 on: July 14, 2016, 10:25:34 pm »
The inductor is more or less a dead short only at DC. Compute the impedance of the inductor at the oscillator's frequency.
Offline orbanp
« Reply #4 on: July 25, 2016, 11:41:35 am »
Hi fnpfar,
That is no way to set the bias for a transistor!
Add a 1k resistor form the emitter to the ground and bypass it with a 100n cap.
Then you can set the bias comfortably!
The oscillator in that configuration runs in the simulator with the bias (emitter) current set to about 1.8mA.
Good luck, Peter
The following users thanked this post: fnpfar
Offline rfbroadband
« Reply #5 on: July 31, 2016, 01:39:59 am »
download a free spice simulator and start by simulating and verifying the bias. Next do transient sim....
Offline uncle_bob
« Reply #6 on: July 31, 2016, 02:46:19 am »
Hi
Where did you get that schematic from and why do you call it a Colpitts?
What is your objective (just a sine wave out)? Why not use a crystal? For 20 cents that would solve a lot of issues.
To do it correctly:
Keep the emitter hooked to the junction of the two caps.
Move the ground to the bottom of the inductor (L1/C1 junction).
Put a 1K or so from emitter to ground
Put a 10K from 9V to the base.
Put a 10K from base to ground.
Run the collector to 9V through a 330 ohm resistor.
Start with C1 = C2
Start with the impedance of C1 and C2 in the 10 to 100 j Ohm range at your desired frequency.
Start with an inductor with a Q > 100 and an impedance of 2x that of C1 or C2 (it resonates C1 in series with C2).
The circuit should come up without the coil in the circuit at:
4.5V on the base
3.8V on the emitter
8V on the collector
Connect the coil and you should see several volts p-p on the 330 ohm resistor. This is with a high impedance probe running into your oscilloscope.
Bob
« Reply #7 on: August 01, 2016, 11:52:41 am »
Thanks a lot for your questions. I tried some other configurations (common base and common collector) and they worked well. Now I understand why that circuit didnt work.
Thank you!.
Fran
Offline tatus1969
  • Resistance is futile - We Are The Watt.
    • keenlab
« Reply #8 on: August 01, 2016, 02:04:13 pm »
don't know if I overlooked it, but what is the value of L?
We Are The Watt - Resistance Is Futile!
