This topic is quite big and I still couldn't figure one thing out: Does the "maker" (or labeller) of those 858 stations make any difference quality-wise? I'm looking for a hot air station with basic features but I'd love to have it in a good working condition outta the box without messing with it (be it inverted cables, no grounding, inadequate internal wiring, etc). From the myriad of options, does any of them stand above?
I don't know about one that stands above, but I can think of one that stands below...
As far as I recall, the chassis wiring flaws are basically universal among brands; expect to at least safety check anything you buy if you're the critical type. As far as firmware and quality of the PCB assembly, any model based on the 858D06 board (e.g. newer YOUYUE 858D+, UVISTAR 858D) are probably among the better & more common sorts. I still stand by my declaration that the Zeny branded units are essentially defective. I don't know how much variation there really is in handpiece assembly quality. I'm willing to bet those are basically all the same.
bitseeker is pretty much right. All this information comes with no assurances that the manufacturers won't change something. For my own research, I didn't consider branding to be really meaningful. Ultimately it's the internals that are the deciding factor. It's the relationship between observable attributes and useful attributes that is impermanent, so be careful.
As far as trying to navigate this giant mess of a thread, the spreadsheet in
this post has an index of all the posts used as examples of each board type. This way, you can find photos of internals of all the different kinds and make your own choice. The index is as comprehensive as I could manage, and includes all board photos I could find on the web. Some of the references do mention where they bought their unit, so that might help too.
