Just out of curiosity, what is the general consensus on still doing these mods? I recently purchased one of these units off amazon and when comparing to the video of the nice Australian man reviewing the unit, these more recent models seem fairly well-built. It's 110V, no exposed wiring issues inside the gun, e.g., the most recent board version, QR code on back to check authenticity, etc... I even checked the temperature calibration out of the box and it was spot on - didn't fluctuate more than 1-2 degrees!
With all that in mind, is it worth going down this path? Even if I wanted to hack the rework station, it seems like it's going to be a pain given that there really isn't a standard to go off of.
TL;DR - 2017 version seems pretty legit if you can confirm it's authentic, so why modify the gun when I may end up exploding it with tenuous firmware update? (Not to mention I don't even own a second heat gun, which it seems would be necessary for this project...) I'd just the same expend the energy coming up with the resources to get an upgraded reflow station and avoid all this to begin with!
