Hi Wayne,
Yesterday night I installed your board in my 230V Kaleep 858D+. Everything went well at start-up : firmware version, fan ON during approx 3 seconds then OFF, operationally it works (no reset, no errors).
Then I began to measure the temperature with a DMM/thermocouple just at the output of the smallest nozzle. I did two runs from 50°C to 400°C upwards and backwards.
Here are the results, compared with the original version with MK1841D3. You can see that there is a big difference between the displayed set point and the real temperature. An other issue is that when increasing the set point the value is achieved without overshoot, as when decreasing there is always a large undershoot (between -20°C to -30°C) before going back to the set point. Let me know if you need some more information to adjust the parameters accordingly. Shall I try to play with the calib pot? Thanks in advance,
Denis
MK1841D3 ATMEGA328P
Set point Run #1 Set point Run #1 Run #2 Mean delta %
50°C 53°C 50°C 37°C 38°C 12,5°C 25%
100°C 106°C 100°C 73°C 70°C 28,5°C 29%
150°C 147°C 150°C 112°C 110°C 39,0°C 26%
200°C 191°C 200°C 154°C 149°C 48,5°C 24%
250°C 234°C 250°C 204°C 203°C 46,5°C 19%
300°C 275°C 300°C 250°C 249°C 50,5°C 17%
350°C 317°C 350°C 295°C 291°C 57,0°C 16%
400°C 363°C 400°C 337°C 330°C 66,5°C 17%
350°C 320°C 350°C 299°C 294°C 53,5°C 15%
300°C 283°C 300°C 258°C 255°C 43,5°C 15%
250°C 240°C 250°C 214°C 210°C 38,0°C 15%
200°C 198°C 200°C 156°C 155°C 44,5°C 22%
150°C 156°C 150°C 115°C 114°C 35,5°C 24%
100°C 113°C 100°C 77°C 82°C 20,5°C 21%
50°C 54°C 50°C 38°C 40°C 11,0°C 22%
