Author Topic: Your favorite aluminium milling/drilling lubricant?  (Read 38398 times)
Online nctnicoTopic starter
« on: October 10, 2016, 07:21:41 pm »
In the past decades I have used alcohol-ish liquids (like Spiritus or ethanol) for helping with milling/drilling aluminium but perhaps there is something around which is safer. Any suggestions?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Your favorite aluminium milling/drilling lubricant?
« Reply #1 on: October 10, 2016, 07:24:18 pm »
In the US, we use WD-40.  Besides Water Displacement, it's the only other thing it's good for!  (Note: it is NOT a general purpose lubricant!)
Seven Transistor Labs, LLC
Offline tautech
« Reply #2 on: October 10, 2016, 07:32:00 pm »
Out of office and unavailable for a few days.
Offline Jeff_Birt
« Reply #3 on: October 10, 2016, 08:04:31 pm »
For application by hand I would a 10:1 mix of WD-40 and Automatic Transmission Fluid (ATF). The ATF is colored so you can see where it is at and it makes it a bit more viscous. There are also many brands of vegetable oil based cutting fluids. I like to use Kool-Mist when I'm using a mister for application. There are also many brands of misters, some will atomize the spray so finely that it creates a fog of vapor in the air that is not the best thing to breath. I switched a few years ago to the Kool-Mist mister and it was a good decision. I ran the small mill for about 5 hours today and used 250ml of coolant (you mix the Kool-Mist with water.)
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #4 on: October 10, 2016, 08:24:20 pm »
I find Servisol switch cleaner works well
Day Job: Mostly LEDs
Offline rob77
  • Country: sk
« Reply #5 on: October 10, 2016, 08:35:25 pm »
i'm lazy and using one kind of cutting oil for everything - actually a cheap one from local hardware store (apparently made in Germany because it states "Bohrol  Schneidol" ) if taking really light cuts to aluminium on lathe or mill then not even bothered to use anything. btw using HSS tools, no carbide.  on the other hand i have a really small lathe (proxxon FD150) and mill (proxxon MF70) and working on small parts only, probably that's why it works for me.
Offline Lightages
  • Canadian po
« Reply #6 on: October 10, 2016, 08:50:06 pm »
Almost anything that cools the cutting edge and provides some kind of lubrication will work. You can use WD40, vegetable oil, engine oil, Vaseline, KY jelly, etc. One thing that does not do very well is plain water.
Online langwadt
« Reply #7 on: October 10, 2016, 08:56:57 pm »
I've tried WD40 and it is not nearly as good as ethanol, plus it smells and leaves a mess.
Offline SL4P
  • There's more value if you figure it out yourself!
« Reply #8 on: October 10, 2016, 08:58:32 pm »
Water does it.
Don't ask a question if you aren't willing to listen to the answer.
Online langwadt
« Reply #9 on: October 10, 2016, 09:00:09 pm »
with aluminium it is not so much about cooling, it is about preventing the gummy aluminium "welding" itself to the tool so you end up rubbing rather than cutting
Offline Gyro
« Reply #10 on: October 10, 2016, 09:15:31 pm »
That's the first time I've seen KY jelly advocated as a coolant! :D
Best Regards, Chris
Offline Neganur
« Reply #11 on: October 10, 2016, 09:19:59 pm »
Isopropanol or IPA or w/e it's called
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #12 on: October 10, 2016, 10:16:24 pm »
As previously mentioned, I love the smell of kerosene in the morning, and just about any other time for that matter.  :P
These handy little reference books below are a must have for anyone involved in the art of swarf creation in my view.   :-+
Sutton Tools AU.
http://www.suttontools.com/
Offline alsetalokin4017
« Reply #13 on: October 10, 2016, 10:24:25 pm »
A9.
It's green, it smells good, and ... it works.
Offline Lightages
  • Canadian po
« Reply #14 on: October 10, 2016, 11:07:38 pm »
Offline T3sl4co1l
« Reply #15 on: October 10, 2016, 11:09:56 pm »
Reminds me of another thought...
What's the correct feeds and speeds for human flesh?  Do you think all those lucky* machinists with a missing finger might know?  :scared:
*There are old machinists, and there are lucky machinists, but there are no old, lucky machinists. ;)
On a lighter note... the correct rate seems to be up to 350 RPM... if you don't believe me, there are websites about it... <verb deleted>ing machines...  :-DD :popcorn:
« Reply #16 on: October 10, 2016, 11:57:39 pm »
For that kind of questions I have some close relatives to turn to. I'm the occasional swarfer and most of what I do is making enclosures for electronics.
Regarding my original question: I think I'll stick to ethanol then even though it means I have to keep the door of the shed open in the winter. I'm surprised by the many answers and even snot (KY Jelly) seems to work  :-DD.
Offline Len
« Reply #17 on: October 11, 2016, 01:49:54 am »
I don't know about that, but here's a guy who has done some videos on machining vegetables.
(Seems like he uses WD-40 for alumin{i}um.)
https://youtu.be/ZZoXcKiHDag
DIY Eurorack Synth: https://lenp.net/synth/
Offline Mickster
  • Country: bm
« Reply #18 on: October 11, 2016, 02:07:24 am »
ISTR Windex being mentioned over on CNCzone but I can't remember the exact situation....
Offline radar_macgyver
« Reply #19 on: October 11, 2016, 05:29:59 am »
I now use Kool Mist mixed with water, but before I bought the spray nozzle I used a squirt bottle filled with denatured ethanol. The squirt action knocked off the swarf, and the alcohol evaporating cooled down the work. The trouble was the headache from the ethanol fumes.
Online langwadt
« Reply #20 on: October 11, 2016, 02:23:40 pm »
headache? you are supposed to lubricate the parts you are milling, not yourself ;)
Offline DenzilPenberthy
« Reply #21 on: October 11, 2016, 02:55:56 pm »
The figure quoted to me when I did my chainsaw qualification was roughly 4.5 ft/sec. I do not wish to ever find this out the hard way!!!!
Offline John Coloccia
« Reply #22 on: October 11, 2016, 06:33:14 pm »
I like Boelube. I was turned onto it when I was doing experimental aircraft building. Works great on aluminum.
Offline rx8pilot
« Reply #23 on: October 11, 2016, 06:42:31 pm »
Tap magic aluminum for manual stuff. After 10 years of CNC machining - this is the stuff I came to rely on for the 'touch-ups' in manual machines. You only need a tiny amount so I got a nice dispenser to accurately place a few drops at the cutting location.
http://www.tapmagic.com/product/2/tap-magic-aluminum
Offline HighVoltage
« Reply #24 on: October 11, 2016, 06:50:21 pm »
I bought a small bottle of A9 Relton cutting fluid for Aluminum a long time ago and it will probably last a lifetime.
I am not sure what is in it, but it works very well.
http://relton.com/a-9-aluminum-cutting-fluid/
