Author Topic: WTB: Good RS-232 to USB cables  (Read 2361 times)
Offline Mr. ScramTopic starter
  • Display aficionado
« on: April 30, 2020, 03:37:30 pm »
Currently I'm looking for some good quality RS-232 to USB cables to use with various pieces of equipment. I'm not interested in overly cheap options, I just want a good product at a reasonable price. I was thinking about getting some OEM FTDI-cables as they're a fairly well regarded brand, but I thought I'd as for experiences and advice before committing. What do you use and can you recommend it?
Re: WTB: Good RS-232 to USB cables
« Reply #1 on: April 30, 2020, 03:49:49 pm »
Tripp-Lite ones seem to be reasonable. Not had any wonkyness from them anyway https://www.amazon.co.uk/dp/B00005V52C
The following users thanked this post: Mr. Scram
« Reply #2 on: April 30, 2020, 03:59:06 pm »
I thought it looked like a wonky brand but I see they're just American.  :-DD Seems to be around the same price as the FTDI ones.
« Reply #3 on: April 30, 2020, 06:09:45 pm »
I have some issues with how FTDI handles their cloners. Having said that, those (real ones) are among the best chips, and are universally supported. The Prolific ones aren't bad, but might require drivers.
If you're on OS X, go FTDI. Only one supported natively. For new macs, you can get good ones with USB-C and Cisco compatible 8p8c-connector. That's my favourite at work right now.
Linux or BSD? Anything goes.
Windows? I don't do that. :-DD
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #4 on: April 30, 2020, 06:38:14 pm »
One more vote for FTDI cables. They work quite well.
I have a few other Prolific-based cables that work well as well, but they are ancient and sometimes finding drivers is a bit cumbersome.
Offline WattsThat
« Reply #5 on: April 30, 2020, 06:55:20 pm »
The overall issue that you’ll run into is that the two most commonly used parts for that functionality, the FTDI232 and MAX232 chipsets are among the most commonly counterfeited parts out there. So, a brand name is the only way to go. This is the most economical one I’ve found that works well:
https://www.digikey.com/product-detail/en/ftdi/CHIPI-X10/768-1138-ND/3103022
Offline Ero-Shan
« Reply #6 on: May 01, 2020, 05:36:23 pm »
I used everything I could get my hands on. All of them worked well up to 19200  bps, but with 115200 they sucked big time. They were used for downloading an image to a µC, and after some seconds the download stopped with an error. Upon closer inspection, I found that at that time there was a bit of just half its wanted width.
Did I say all? I think FTDI worked even with its virtual COM port driver (or did I already use D2XX?). So we chose FTDI for our own USB-Serial adapter. The D2XX drivers allow downloads with 1 Mbps with no problems whatsoever.
You're allowed to loath them for their attempts to brick clones. But they do work very well.
« Reply #7 on: May 01, 2020, 06:13:59 pm »
That what I'm concluding as well. It was a stupid move though I suspect they never really grasped what they would cause. Can't really argue with the product, though.
Offline kleiner Rainer
  • Rainer DG1SMD JN48ts
« Reply #8 on: May 01, 2020, 07:48:35 pm »
Have a look at Silabs CP2102N, their driver support is also very good:
https://www.silabs.com/interface/usb-bridges/usbxpress
https://www.silabs.com/products/development-tools/software/usb-to-uart-bridge-vcp-drivers
Win, Mac OS X, Linux and Android drivers. I use them for ham radio projects, especially for transceiver control (Yaesu and Icom). The only thing to keep in mind when ordering is to look for the "N" suffix, because the older CP2102 are "not recommended for new design", but still available from China as break-out boards.
Rainer
Offline TK
« Reply #9 on: May 01, 2020, 08:15:44 pm »
You should clarify if you need USB-RS232 or USB-TTL cables.  AFAIK FTDI does not manufacture USB-RS232 cables.
I was only familiar with the FTDI to TTL cables... sorry
« Last Edit: May 01, 2020, 08:33:40 pm by TK »
Online oPossum
Offline Picuino
    • Picuino web
« Reply #11 on: May 02, 2020, 09:31:33 am »
You should also consider installing a RS232 port directly on the PC.
https://www.amazon.com/StarTech-com-Serial-Adapter-Card-PCI2S550/dp/B00006B8C0/ref=sr_1_1?dchild=1&keywords=pci+rs232&qid=1588411826&sr=8-1
The USB-RS232 adapters have several problems that are not easily solved and that the RS232 PCI cards do not have
« Last Edit: May 02, 2020, 09:34:19 am by Picuino »
« Reply #12 on: May 02, 2020, 10:20:17 am »
Much as the USB cards, those are not all made equal either. Nearly all RS232 cards don't have the correct signalling voltages which should be up to +/- 25V.
Years of arguing with shitty serial cards, built in serial ports and stuff trying to program PICs with it. Ugh.
Online rsjsouza
  • Eternally curious
« Reply #13 on: May 02, 2020, 10:28:18 am »
The major caution I see with PCI cards is their driver availability, especially If you intend to use this port across OS versions or with Linux.
Your experience is Interesting. I have used both the FTDI and the old Prolific cables with several configurations (legacy computers, embedded boards, hardware handshake) and they work very well up to 115200bps, with an edge to FTDI and their higher speeds above this mark and their broader device driver support.
« Reply #14 on: May 03, 2020, 07:33:12 pm »
It's a good question. I'll need to check which protocol the various devices actually use.
« Reply #15 on: May 03, 2020, 07:34:25 pm »
What kind of problems are we talking about?
Offline Picuino
    • Picuino web
« Reply #16 on: May 03, 2020, 09:38:39 pm »
USB connector is not robust and can be disconnected with vibration.
In that case the COM port loses the connection.
« Reply #17 on: May 03, 2020, 10:27:09 pm »
Hot snot fixes that. Seriously. I have actually used it to do that  :-DD
Offline Marck
« Reply #18 on: May 03, 2020, 10:51:05 pm »
We use SEALEVEL sealink+ 232-db9. Part number 2105R. We have tested many over the years with varying results.  Most will work well for basic command line duties but almost all will not work when transferring config or application files. Causing corruption of the transmitted file or complete failure to transfer.
The Sealink has been very successful to the point i don’t think i have had any issues in the last few years. I have to admit that i only have to resort to using a serial connection a few times a year. But before we found these ones serial transfer was always problematic.
It plays well with windows 7 and 10 from my experience and i have used it on gear from two or three manufacturers and probably a total of five or six products.
I still keep an old laptop that has a com port on it running XP and use that where i can. But its getting harder and harder to get newer applications to work on XP.
M
M
Offline bateau020
« Reply #19 on: May 10, 2020, 09:27:57 am »
If you have a Mac, avoid Tripp-Lite USA19HS. That one always worked for me, but it since the latest major OS update it's no longer supported natively by the OS. And when looking, none of the adapters they have are officially supported on the latest MacOS it seems.
I still manage to use FTDI and Prolific chipsets though. FDTI requires an updated driver (the OS natively supports it now it seems), and one of my serial tools complains about the OS's support for Prolific. MacOS might be a bumpy ride.
« Last Edit: May 10, 2020, 09:46:46 am by bateau020 »
