Author Topic: Worthwhile solder sucker all-in-one?  (Read 8777 times)
Offline tom66Topic starter
« on: December 17, 2012, 10:04:45 pm »
Cheapie thing:
http://www.maplin.co.uk/electric-de-solder-pump-96859?c=maplin&utm_source=endeca&utm_medium=endeca_search&utm_campaign=N37CH&utm_content=De-soldering+Tools
I've often found it hard to remove large hybrid modules and transistors on large heatsinks. I've got a 55W Antex iron and a 35W Aoyue iron (rubbish), but no desoldering equipment apart from using a normal hand powered solder sucker and iron separately. Does combining the two make for a better device? I doubt temperature control is necessary for most desoldering work.
Offline peter.mitchell
Re: Worthwhile solder sucker all-in-one?
« Reply #1 on: December 18, 2012, 09:12:42 am »
if its anything like the manual ones, damn they get blocked often.
Offline nctnico
« Reply #2 on: December 18, 2012, 12:32:43 pm »
You better get a hot air gun like the Atten 858D.
Offline Bored@Work
« Reply #3 on: December 18, 2012, 02:15:48 pm »
It is an Zhongdi Model ZD-211. Zhongdi means you don't get complete crap, but you don't get first class quality either. And since it has a mains powered, unregulated heating element you have no real control over the temperature. And together with the manual pump you have limited suction capacity.
I have seen them for something like 5 Euro in the past, and recently for something like 9 Euro. Which is probably what they are really worth (more close to the 5 Euro).  For 5 or maybe even 9 Euro it might be fine to have one as a novelty item or emergency tool. But for 16 GBP (> 19 Euro)? I don't think so.
http://www.china-zhongdi.com/images/products/dpwm01/zd-211.jpg
http://www.china-zhongdi.com/dpwm01.htm (showing the wrong image for the 211)
Offline KD0CAC John
« Reply #4 on: December 18, 2012, 02:32:03 pm »
In almost any case there is never just one tool does it all .
I bought a Metcal desoldering gun , very simple , uses shop air to make vacuum , making the gun smaller and no repair of vacuum pump .
A hand held metal spring powered solder sucker is hard to beat for small jobs .
Then having a stash of solder wick .
To depopulate a hole board to add parts to inventory , use a plumbers hand torch , propane and tap board on bucket :)
« Reply #5 on: December 19, 2012, 11:46:26 pm »
I had an Aoyue 968 (that's the other iron, plus hot air.) It caught fire. Hot air heating element failed.
Luckily all that was damaged was the element, so I was able to replace it, but I don't really trust it any more. Especially as the soldering iron also crashes occasionally and locks up, luckily it doesn't go full power but you have to reset it... now I know the purpose of the reset button!
Anyone know of a powered, mains soldering iron that just accepts an air input? The 968 has a suction pump so I can use that to suck the solder. That would allow me to make a super cheap desoldering iron.
Offline ptricks
« Reply #7 on: December 20, 2012, 04:00:44 pm »
You could use one of the desoldering irons that has the bulb attachment and remove the bulb, connect your suction line instead.
http://www.amazon.com/ECG-J-045-DS-Watt-Desoldering-Iron/dp/B00068IJSG
« Reply #8 on: December 20, 2012, 06:23:41 pm »
A little out of my budget range...  :(
Offline vtl
« Reply #9 on: December 21, 2012, 06:40:36 am »
Cheapie thing:
I've got something that looks exactly like that in the link, but in blue. I bought it for $12 off ebay. Worth having I guess, the thing is a bit hit and miss, certainly better than using a solder sucker + soldering iron. If you think you're able to just suck off all the solder in one hit you're sadly mistaken. Usually takes at least 2 shots on a pin and even then youll most likely need to clean the rest off with braid.
I just think its a pain in the ass having to take it out of the cupboard and wait for the thing to heat up. I only bring it out if im desolding a big DIP device.
Offline mianchen
« Reply #10 on: December 21, 2012, 10:06:02 pm »
I got mine (exactly same as photo) off eBay for £7. It work great for the first 10 hours or so until the tip/head broke. :--
Offline IanB
« Reply #11 on: December 21, 2012, 10:18:29 pm »
Can you find this item in the UK?
http://www.radioshack.com/product/index.jsp?productId=2062731
It's a bit slow to heat up, but once it gets going it works a treat.
I guess Tandy disappeared, right? Did they get taken over or absorbed, or are they just gone?
Offline TorqueRanger
« Reply #12 on: December 22, 2012, 09:31:47 am »
I know it's not what you asked for but here is what I use and have no problem getting stuff done ...
Solder sucker-It's pretty big
http://www.ebay.com/itm/Soldering-Sucker-/320801379333?pt=LH_DefaultDomain_0&hash=item4ab1409405
Solder wick- Chemtronics 60-3-5 Solder-Wick
http://www.ebay.com/itm/10-Chemtronics-60-3-5-Soder-Wicks-ESD-Safe-Lead-Free-Desolder-Braid-/181048041657?pt=LH_DefaultDomain_0&hash=item2a274de0b9
Offline FenderBender
    • The Solid State Workshop
« Reply #13 on: December 22, 2012, 09:15:19 pm »
I know you don't live in the US but RadioShack has a desoldering iron that is like $10USD. I don't know if there is an equivalent in the UK. But it works quite well. Can't complain.
Offline Wartex
    • http://headsplosive.com
« Reply #14 on: December 22, 2012, 10:50:02 pm »
Hakko 808. Everything else in the posts above is trash, trust me.
