Actually I found one such wireless item for magnetic stripe but it is operating in completely opposite way comparing to what I want. It is operating in a way that the item is put close to credit/debit/prepaid cards POS (wireless or wired) terminal and then the terminal reads the magnetic stripe with no contact at all. I heard that the item is just doing some kind of electromagnetic field in its close environment and that field can be read by POS. I don't want that.
What I search for doesn't have much to do with POS at all, not even with ATM. I am looking to hire electronic developer who could make device in a way that i put it close (how close would be discussed with developer) to the card regardless in what position the card is, even if back side is placed on the table, and then the device could remotely read that particular magnetic stripe for track 1 and track 2.
Now imagine the warehouse: One box either for departure or for arrival (new material) has one card attached. Another box has another card attached and so on. All the data of magnetic stripes are in the database but reading every single card (reading the magnetic stripe) of each and every box can be time consuming. It would be better if employee simply walks around those boxes, the data from magnetic stripe cards (one card per one box) would be saved into the device. Once done, device can be connected to computer and data from magnetic stripes can be instantly compared with the database. If NOT missing, this means the order (different quantity of boxes) for particular can be shipped to the customer - it is ready. If missing, the required order is not yet manufactured and we can investigate further with manufacturing department where are packages stopped. They can track the order, see what products are being manufactured for this order, see what kind of manufacturing phases are required and can go to particular machines or wherever items are.
Ian.M I apologize but I have no idea what are you talking about. Would appreciate that you explain in nontechnical/nonelectronic way but kindly keep in mind that from magnetic stripes I would need gathered/collected remotely track 1 and track 2. I had to repeat that so wrong data wouldn't be collected.
