The JBC is a great station, but it's expensive. Personally, I would try to find a Hakko FX-888 (not the D version but that's my preference). Hakko makes a wonderful station at a fraction of the price of the JBC. I had my labs outfitted with Hakko stations. I'm doing production work now for my business, building 100 boards at a time. The Hakko was OK, but I wanted something that could pump more heat into the joint quickly without over driving, and I also wanted the convenience of the quick change tips, the digital readout of actual tip temperature, and the lighter, more comfortable hand piece, the cable management, etc, because I'm doing it 12 hours a day trying to get ready for a new product launch.
Tip life is also important to me. Each unit is about 120 joints, ranging from delicate and oxidized Germanium diodes to heavy duty soldering of PCB mount control pot mounting legs. That's 12,000 joints each run. JBC claims their tips are good for 25,000 to 100,000 joints, and I know their tips last much longer than most because of the cool down. However good the Hakko tips are, and they are VERY good and have outlasted everything else I've used so far, I was already starting to see degradation of the tip after the first 30 units. The tip is still usable but it's definitely showing wear and would have to be replaced fairly soon. They also oxidize so quickly because it sits in the holder for 5 minutes baking while I prepare the next group of components to be soldered, and it's a pain in the butt to keep doing a ritualistic cleaning when you're trying to work quickly. The JBC iron cools down and it take but a second or two to bring it back to dead clean and new condition.
My opinion is that unless you have money to burn, or you really just want the JBC because it's cool, get the Hakko. To give an idea, my first Hakko tips lasted 10 years of hobbyist and guitar building use. These days, I probably do more soldering in one or two days than most hobbyists do all year. You can get the JBC later. It's always good to have two solder stations anyhow. If you do have the money to burn, though, the JBC is fantastic.
That's just my opinion.
