Poll
Which soldering temperatures (3 default ones) would you prefer as default in a soldering iron for SMD components?
200
1 (0.8%)
225
0 (0%)
250
4 (3.2%)
275
14 (11.2%)
300
18 (14.4%)
325
28 (22.4%)
350
33 (26.4%)
375
13 (10.4%)
400
5 (4%)
425
3 (2.4%)
450
4 (3.2%)
Other
2 (1.6%)
Total Members Voted: 62
Author Topic: Which soldering temperature would you  (Read 13998 times)
Offline riccardo.pittiniTopic starter
« on: September 18, 2014, 01:07:48 pm »
I'm working on the development of a soldering iron. The idea is to have 3 preset temperatures (like: low mid high) and a custom one (from 150-450C).
The soldering iron is mostly for small components (e.g. SMDs) with power of about 40W (so not ideal for 1cubic meter of copper... ;)).
Which values do you suggest for the preset ones?
My thought would be:
250 - 350 - 450
What are your suggestions? (everyone has three votes :))
Thanks for the help!!!!!!!
Offline zapta
Re: Which soldering temperature would you
« Reply #1 on: September 18, 2014, 01:14:47 pm »
Look at the preset temperatures that metcal uses for its tips.
Offline EEVblog
« Reply #2 on: September 18, 2014, 01:30:06 pm »
700F has always been the standard fixed tip temp for general purpose through hole soldering.
600F for finer smaller SMD and sensitive stuff.
800F for beefy stuff.
These are your standard old school Weller or metcal tip temps.
But of course these "standard" temps are entirely dependent upon the thermal capacity and recovery time of your top and element system. And you can't just go by the wattage.
So anyone who claims one temp is best without measured performance data on the tip and system being used is talking out their bum.
Yes, old school F here.
IMO 250C is too low for all but the best capacity irons like JBC or Metcal et.al.
For SMD I'd think 550F, 600F, 650F is likely to be the sweet spot.
« Reply #3 on: September 18, 2014, 01:37:37 pm »
Thanks for the hints. It is more on a user point of view :).
The 250C idea was for small components not lead free.
Everything is part of a custom made soldering iron, that i might release in open-HW.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #4 on: September 18, 2014, 01:51:10 pm »
Part of the magic is in the tip design. Are you going to use an of the shelf tip system or do your own?
Edit: I strongly suggest adopting a JBC tip and handle and focusing all your efforts on an affordable base unit that will perform as good as the original
« Last Edit: September 18, 2014, 01:55:55 pm by robrenz »
Offline zapta
« Reply #5 on: September 18, 2014, 03:08:11 pm »
Any estimation how much this will cost the overall cost?
There is a similar project with Metcal in another thread.
Offline Rasz
    • My random blog.
« Reply #6 on: September 18, 2014, 03:30:13 pm »
if you need 450C then it means you are using wrong tool for the job
I guess its ok if you need that 450 once a week or something
but couple of times a day would go a lot smoother with something with adequate thermal capacity. Oki, ~1KW heat gun, ~couple KW preheater etc.
Offline SteveyG
  • Soldering Equipment Guru
« Reply #7 on: September 18, 2014, 08:03:56 pm »
Other than special circumstances such as soldering to flexi pcbs, I don't think there's any need for anything other than 325C.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline nctnico
« Reply #8 on: September 18, 2014, 08:36:12 pm »
250 - 350 - 450
You don't need 3 temperatures settings. Only one setting works best: 330 deg C for both lead free and leaded. The mistake many people make is cranking the temperature up on a tip which is too small for the job. This just results in burning up the flux too quick and making a bad solder joint. In other words: get a wide variety of tips and have an iron which allows to change them quickly. BTW: 40W is on the low side. Better double that.
« Reply #9 on: September 18, 2014, 08:49:26 pm »
I know 330 it is the perfect temperature, it is kind of magic number. :D
It is a high precision (fine tips) soldering iron for smd.. so 40W is more than enough (you can easily solder smds like 0805 1206 etc with 10W at 330C).
It is not designed for bigger staff ;)
Offline nctnico
« Reply #10 on: September 18, 2014, 09:19:49 pm »
You'll need some power to solder the heatsink pad of a QFN (through the thermal vias) or the tab of a bigger transistor or diode. A soldering station which can't do that is pretty usless. Besides that I use a really big tip and solder 4 pins of a QFN or TQFP at once. Components attached to ground planes (even with thermal reliefs) can suck up a lot of heat too. IOW there is a good reason most irons are 80W: you need it!
Offline eliocor
    • rhodiatoce
« Reply #11 on: September 18, 2014, 10:41:32 pm »
By default (Weller stylus WSP80 + LT K tip + SnPb solder) the default temperature I use is 314°C (pi*100: very easy to remember).
Some much higher for Pb free solder (from 330 to 340 °C)
Offline zapta
« Reply #12 on: September 18, 2014, 10:58:35 pm »
+1
This is IMO the main disadvantage of the common Wellers and Hakkos.
I switched a year ago to a solder iron with quick tip change (MX500) and was surprised how often I change tips and how useful it is.
It should be an important factor when evaluating solder stations.
Offline EEVblog
« Reply #13 on: September 19, 2014, 12:21:26 pm »
it is for your traditional irons. But get a JBC, Metcal or one of the newer induction heating irons and you'll find that it's actually too high for ordinary stuff.
I leave my JBC on 280C for regular work now, whereas I had to use that magic 320-330 figure on my Hakko's to get a similar performance.
Lower temp is always preferred if your iron and tip is capable of getting the job done.
Offline robrenz
« Reply #14 on: September 19, 2014, 12:44:03 pm »
+1 and the reason for my reply#4
Offline nctnico
« Reply #15 on: September 19, 2014, 12:47:47 pm »
Lead free or leaded?
« Reply #16 on: September 19, 2014, 01:24:23 pm »
I mostly use 330C for anything reasonably small (both lead and lead-free) but not too small or delicate (then lower temp.).
It is also a matter of speed... 330C for me has often been a good trade-off also for fast soldering ;)
Anyhow, I am not using beefy irons for small staff. I use tiny ones (e.g. ersa/weller micro ones), perfect for small cramped electronics where a normal size tip would touch too many components at a time ;)
Offline robrenz
« Reply #17 on: September 19, 2014, 01:40:59 pm »
JBC does not mean beefy Irons, it means exceptional thermal response. There are plenty of JBC micro tips available. IMO if you want to get any interest in you project, duplicate the JBC base unit performance and connectors for the irons. That could include multiple handle ranges and double outputs for tweezers. Do that and you have my interest and probably many others on the forum.
« Reply #18 on: September 19, 2014, 02:16:58 pm »
I explain better what I am doing:)
Me and a colleague in our spare time we developed a soldering iron (not soldering station) that could perform as JBC/weller soldering stations (several hundreds $) but is shrimped down to a soldering stylus.
We simply wanted a cheap, with very high quality tips soldering iron for small components.
I just wanted to see what people thinks about their preferred soldering temperatures. E.g. maybe 260C - 330C - 400C.
Offline SteveyG
« Reply #19 on: September 19, 2014, 02:52:12 pm »
For leaded or lead-free? When I had my IPC training, the trainer recommended 320 has a good all round temperature to ensure good wetting throughout the joint.
He demonstrated under microscope the difficulties using some of the advanced rework techniques at lower temperatures which are not necessarily noticeable by eye. All lead-free soldering though.
Offline G7PSK
  • It is hot until proved not.
« Reply #20 on: September 19, 2014, 02:56:05 pm »
What would be good is an iron of about 250 watt yes I mean 250 watt and hot swap-able tips plenty of power to heat tips in seconds and a whole range of tip sizes instantly available in a magazine.
Offline Fsck
  • sleep deprived
« Reply #21 on: September 20, 2014, 03:37:46 am »
at the moment, the poll has a very interesting gaussian distribution.
"This is a one line proof...if we start sufficiently far to the left."
Offline miguelvp
« Reply #22 on: September 20, 2014, 06:32:34 am »
Nah, it's just giving us the middle finger ;)
I'm only one up high the mean, meaning I selected 325, 350 and 375 so I guess I helped a bit to get it better distributed :)
Offline Rasz
    • My random blog.
« Reply #23 on: September 20, 2014, 02:14:51 pm »
lies, damn lies and statistics
 would be better if you asked for temp and model of soldering iron at the same time, would show people with shitty equipment on the upper end of the scale :)
Offline dfmischler
« Reply #24 on: September 21, 2014, 11:44:19 pm »
315 (i.e. 600F).
