Author Topic: Which small case Linux box to choose?  (Read 14374 times)
Offline linux-works
    • netstuff
Re: Which small case Linux box to choose?
« Reply #25 on: February 17, 2015, 02:09:11 am »
I have not checked celerons for a long time, but the atom's I've used were great for most things that didn't need a lot of cpu.  i/o was decent and the chipsets were decent enough, as well.
the nvidia ion gpu that was 'connected' to to the atom was quite good for its day.  still good for most video types.
this atom (n2800) is a low profile board and it fits the m350 case and allows a horizontal pci-e card to be mounted in a very small space.  not sure celerons are that low profile (?)
Offline Monkeh
« Reply #26 on: February 17, 2015, 02:12:56 am »
fanless atom mini-itx box.
done.
agree, atom is done :D atoms are dead-slow compared to other modern celeron CPUs.
Other modern Celeron CPUs like the J1900, which is a Bay Trail-D? You know.. an Atom.
The J1900 is an Atom with bits turned off (ECC, NX, AES-NI).
Avoton and Rangeley would like a word with you outside about being called dead slow.
« Last Edit: February 17, 2015, 02:19:21 am by Monkeh »
Offline linux-works
    • netstuff
« Reply #27 on: February 17, 2015, 02:19:18 am »
I bought this fanless heatpipe style case recently:
http://www.amazon.com/Perfect-Home-Theater-FLM-8-Black-aluminum/dp/B0072IRVKK
its a knock-off of the streacom brand (I have both, actually, and the streacom is slightly better made but only slightly; and its $60 more).
the lowest power i3 I could find was:
http://www.amazon.com/gp/product/B00EUVEFEC
i3-4130t at 35w
truly a low-power cpu that can work well in a fanless case.
good mobo for it:
http://www.amazon.com/gp/product/B00KRUX0PU
in fact, I found a (pretty hard to find) i7-4790t:
http://ark.intel.com/products/80809/Intel-Core-i7-4790T-Processor-8M-Cache-up-to-3_90-GHz
via special order at my local store and its 45w, with 4 cores and 8 threads.  builds linux kernels from source in very quick time!  video encodes with all 8 threads very fast, too.  and still fanless.
forget about the i7, you won't be able to find that T-version.  but the i3 is quite affordable (I think so) and its a very capable cpu.  its my main work desktop and with 16gig of ram, it will be a while before I have any desire for an upgrade.
fanless is the only way I build, these days.  can't stand system noise!  and with those heatpipe cases, you can go fanless and not have to resort to super low-end cpus.
Offline Monkeh
« Reply #28 on: February 17, 2015, 02:20:26 am »
I think they're all being sucked up by OEMs and the upcoming i7 NUC.
Offline linux-works
    • netstuff
« Reply #29 on: February 17, 2015, 02:23:24 am »
I don't have any pics of my fanless case inside, but here's one user who has some photos.  note, he mounted his heatpipe metal end-caps wrong, but that's his fault, not the case's ;)  and I have no idea why he went with a fan.  kind of a waste of a $200 case if you buy heatpipes and then cram a fan in there (doh!).  but if you ignore his bizarre-ness, this is how that streacom case looks inside.  I liked it enough to buy two of those for myself:
when I take some shots of my own, I'll post those.  mine will look better than his, lol.
Offline linux-works
    • netstuff
« Reply #30 on: February 17, 2015, 02:25:51 am »
you can't normally buy the t (tray) versions and they only come with 30days warranty (in the US).  I had my store search them out and they found 5 of them (a few months ago) and they said that was it, no more left.
the new gen will have some low power chips in i7, too, I would guess, so if the haswell stock is gone, wait for the next chipset.
btw, with that i7 chip and the hd4600 video onboard, I am able to drive my vizio display (brand new, m-model 39") at 1920x1080@120hz.  yes, real actual true 120hz from the intel video out (hdmi 1.4) into the vizio.  120hz is NIIIIIICE!  I'm so glad I decided to splurge on the i7 for my htpc ;)
Offline Monkeh
« Reply #31 on: February 17, 2015, 02:29:01 am »
That fan probably makes less noise than the mechanical HDD and will substantially help with cooling the rest of the system.
Now, as to why he put a mechanical HDD in there..
Oh, right, tray version. They're semi-available here but there can be delays. OEMs get priority. That one's been overdue at my usual supplier for about a week, it'll crop up again..
Offline zaptaTopic starter
« Reply #32 on: February 17, 2015, 02:33:45 am »
Is this a reasonable option?  I presume the 30G SSD is included and can later be upgraded and that Linux is supported.  I5, fanless, 4G ram and wifil.   12VDC adapter not included, right?
http://amzn.com/B00P7K19MQ
Edit: this one comes with 128G SSD.  http://amzn.com/B00P7KUNJQ
« Last Edit: February 17, 2015, 02:37:22 am by zapta »
Offline Monkeh
« Reply #33 on: February 17, 2015, 02:42:32 am »
I would get something from a better known brand than ShenZhen Qotom Technology CO., LTD.
Options on Newegg around the $300-350 mark:
http://www.newegg.com/Product/Product.aspx?Item=N82E16856102069
http://www.newegg.com/Product/Product.aspx?Item=N82E16856164015
http://www.newegg.com/Product/Product.aspx?Item=N82E16856164007
These all need an SSD and RAM as well, mind. But at least they come with proper power supplies.
Linux should not be a problem.
I believe they have fans but they are very, very low power at idle. They shouldn't be loud.
Offline linux-works
    • netstuff
« Reply #34 on: February 17, 2015, 03:02:26 am »
if you can find it (and its not hard to) - its still a better idea to go with standard motherboards and standard parts.
the mini-itx is a nice small form-factor and its standard.  the nuc is not a standard (its intel-only) and other small bricks are proprietary.
in the long-run, its better to go with replaceable parts.
and don't settle for a fan.  its just NOT needed anymore.  don't be tempted.  stick to your goals of 100% fanless.  5 or more years ago, it was hard to do.  today, there are lots of fanless choices for system builds.
Offline linux-works
    • netstuff
« Reply #35 on: February 17, 2015, 03:07:13 am »
its just silly to spend $200 on a case - with big fancy heatpipes - and then hack in a fan where it never belonged.  maybe he picked a higher power chip but the solution is to use the 45w or lower chips (I would not even use 65w chips in that case) and not to garbage the whole thing up with a fan like that!
when I found an i3 at 35w, I grabbed it.  that's a nice number for passive cooling without needing a big heatsink.
« Reply #36 on: February 17, 2015, 05:04:25 am »
My concern is also dust, this will sit on a floor near the cable modem and a fan will accumulate a lot of dust inside over the years.
As for power supply, if I will buy a Chineese product, I will make sure to replace the 12V power supply with a quality one and a better connector that don't come off easily. Basically I want to install once and forget about its physical existence.
Offline linux-works
    • netstuff
« Reply #37 on: February 17, 2015, 05:19:46 am »
that was one appeal of that n2800 intel atom board.  atx voltages are broken out onboard so you give the board just an 18v laptop supply and the board (from intel, which I trust to not use fake parts) does all the important voltage regulation.
I like to minimize failure contact points.  so the m-sata drive 'bay' is a must-have for me, the onboard psu is, and if I can avoid having any option modules dangling from wires (like sata drives or pci-e cards) so much the better.  the atom cpu is soldered on, so no worries about sockets.  its heatsink is designed by the manuf, so no guesswork there.  its as industrial as you can get while still being consumer priced.
its an old model, though.  probably not buyable anymore, but it gives an idea of what to look for, in a mini-itx.  the less connections you have, the better.  one of my n2800's is my pfSense firewall.  throw it in a corner and forget it, just what you want.
Offline linux-works
    • netstuff
« Reply #38 on: February 19, 2015, 10:54:54 pm »
