I purchased a set of Hozan JIS screwdrivers for working on Japanese equipment. Nothing to write home about. They work, but weigh nothing and feel pretty cheap, but the tips are precision and they worked well. My Xcellite and other small hand tools I've used for electronics repair are nearing 40+ years for the most part and I've started to replace many of them. Plastic on much of the old stuff is outgassing, vinyl coatings long exposing bare metal, joints loose, and some tools have been resharpened or squared to the point of dysfunction. I guess I'm one of the rare souls that actually maintain tools that were once considered high quality.
I made a chance buy on Ebay of a few of the Vessel branded screwdrivers. These are impressively made. I wound up buying a complete set of the full tang drivers and an insert bit impact driver. That latter is quality like I've never seen packaged in an old fashioned steel box. I don't know if manufacturer makes and entire line or just the drivers are distributed in the states. I've read online that their hex keys and drivers with an odd shapped tip, unlike the ball type take the mystery out of metric hex tools having a tendency to slip in japanese hex fasteners at higher torques or easily bite the walls and remove fasteners where standard ones don't especially in Japanese autos and motorcycles.
After years of hearing about the JIS crosspoints, the cheaper Hozan's proved the point of easily gripping badly cammed out older crosspoints and the positive feel they have that's unlike the regular phillips or even the pozidrives with a lock and key sensation. There seems to be a similar difference in the slotted Vessel drivers. They seem to fit slots more positively on japanese equipment much better then fresh, high quality insert bits or regular slotted drivers. After reading about the hex tools, it makes me wonder if across the board, japanese specs might be slightly different and you really need the proper tools for the ideal fit.
Anyone with similar experience and to what degree Vessel is sold across the pond?
I'm not one to get excited over a screwdriver, but after all these years, it's like discovering something that's been under your nose the entire time. If Vessel only makes drivers, the price is actually comparable to most electronics grade drivers and cheaper then Snap-On or any of the premium mechanic's brands like MAC in the states.
