Author Topic: What's the highest magnification you use on a microscope and why?  (Read 3888 times)
Offline jpanhalt
Re: What's the highest magnification you use on a microscope and why?
« Reply #25 on: April 19, 2024, 08:10:24 am »
what microscope can do like 100x without a white cloud starting to show up in the picture? its useful for various things like PCB sides, connectors, etc. but a electronics one needs a huge base to be useful at that range (rail system)
Do you mean 100X objective (resolving power) or 100X total magnification?  Presumably, you are asking about viewing opaque objects, not transmission microscopy.  The working distance for a 100X objective in a typical microscope is quite small, e.g., negative in air, which is why oil immersion is used.
For total of 100X magnification, you can use a 5X objective and 20X eyepiece.  Some dissection/inspection microscopes may do that.  Mine only goes to 4X objective.
Offline coppercone2
« Reply #26 on: April 19, 2024, 12:56:13 pm »
well maybe not 100x, but at high zoom, its usable but there is white fog. oil is not really practical in this situation. I figured its just a consequence of such high zoom. It stops being 'nice' at like 40x.
Say looking down from the top on a BNC connector center pin hanging in a arm off the side of a table (held in small helper hand), for microscopes on big articulating arm/rails (heavy, big and hard to adjust... you gently tap them to get the image centered after the screws are tightened lol)
actually better way to describe it might be a off blue/yellow haze, not white fog, and they are always stereo (for electronics)
« Last Edit: April 19, 2024, 01:05:38 pm by coppercone2 »
Online Phil1977
« Reply #27 on: April 19, 2024, 01:32:49 pm »
That may be a bad case of out-of-focus-chromatic-aberation. This frequently happens with optical systems that are better specified than they really are - like all these toy microscopes and telescopes with astronomic magnifications for little money.
I don't say that yours is *such* a bad design, but with a really good design a flat target (e.g. a money bill or better some IC die) stays sharp and crispy over all available magnifications.
Offline coppercone2
« Reply #28 on: April 28, 2024, 01:39:42 am »
yeah its for 3d objects what I mean is if you use a stereo microscope and then you get a high zoom one (in the 1000$ range) it gets worse the more you go
I think its extremely useful. i mean you either can see it or not see it. with how small everything got, you basically won't say that its a waste of money
100x lets you look at 1 number on a penny. thats still not that small. for really looking at a 0402 part its not like its a bad buy
You just won't see the problems without zoom. see no evil there is no evil? ???
but there is a problem, the rail microscopes are god damn huge
also, even more zoom, maybe... for looking at glass diodes. just for diodes 200x :)
« Last Edit: April 28, 2024, 01:49:45 am by coppercone2 »
