has anyone experience with different versions of the WMRT (and WMRP) soldering irons? I am about to buy one to be paired with WT2M station. Unfortunately I find different types of irons, some are 12V, some are 24V. I am confused from Wellers datasheets, which statest WT2M outputs 24V.
Is all the irons both 12V and 24V compatible? Maybe it is just bad marketing, where the WMRT has two separate heaters, each working on 12V (so they sometimes call it "24V"). Or is is completely different iron for different market?
I do not have one available, at least I could measure the resistance of the heater (so I can calculate 2x40W power).
I was also looking into the connector pinout, but could not find pinout for WT2M. Anyway some seems to have both options available, 12V and 24V on same pins. Can someone take me out of the confusion? Thanks a lot.
