Chinese lamps are in the most part pure junk, there may be some good ones but most are cost cut to an extreme. The ones made in Indonesia and Singapore and other South East Asian countries are a lot better, and the best are made in Europe. USA made ones are not bad, but they have dropped in quality as the production moved to cheaper labour places like Mexico.
Best lamps I have were made in Hungary, and the ones made in Poland are as good, made by Phillips in the old Tungsram plant there.
Worst currently are the batch of Radiant branded lamps i have at work, but as I have gone through a typical 2 year stock if they were Osram or Phillips in a 4 month period they will not be there long. Almost as bad are the Applo lamps i bought as I needed a few tubes, about 30 % go mercury starved in a few days, some of one batch did 5 years but most barely did a year.
Just remember that with the voltage multiplier used there you will have a black ring at the negative electrode within a hundred hours due to ion migration and it will destroy the anode end fast. But for a dead lamp still holding vacuum it will give a good amount of extra life. I have tried some on a neon transformer, they light as long as there is still wire into the envelope, though it only lasts until the glass burns a hole through.
