I picked up a black and decker model for $40. It has a pair of quartz elements on the top and also on the bottom. I guess each one is probably 700W, so both together 1400W. There is a convection fan as well, but it doesn't seem to push too much air so I doubt any components getting blown will be an issue.
I'll try and mess with the controls and see how close I can get to a leaded reflow profile manually, but I really want to build a PID controller for it as a learning project. I've been doing some PID stuff and I won't mind testing what I've learned to see if it will work.
Here are a few questions I have:
1. What makes a SSR get hot? Switching speed or simply the current going through it?
2. For 12.5A @ 120VAC, how large a SSR should I get? 25A? 40A?
3. When you read about reflow profiles - are they talking about the air temperature around the board, or what the board goes through itself? Should I mount a sensor on a board or in the outgoing air stream from the convection fan?
4. I've read that some people will insulate the oven more. Does this involve the area between the interior metal shell and the outer metal cover? Someone mentioned fiberglass for this, can it take the heat without damage or burning?
Thanks,
Alan
