The SONY MEU-WX2 is(was
) a professional video color processor and video standard converter/display device.
That was a lot.
Basically you connect a video source (many inputs like SDI, composite, ...) and get DVI output. This device is usually used as a video display monitor on TV studios.
I want to connect a non SONY monitor to it. :'(
The monitor needs to provide 1280x768. Which should not be a problem, unless there is no way to make set this resolution.
The device is quite picky and does not accept any monitor. I guess it detects proper display by the EDID standard.
https://en.wikipedia.org/wiki/Extended_Display_Identification_DataThere are some adapter boxes like the
https://www.extron.com/product/edid101d#features from a professional manufacturer like Extron available.
Has anyone had some success with this approach?
Is there a DIY EDID data spoof box available?
Thanks a lot.
