Thanks again nanofrog.
That Waytek crimper (re-branded Pressmaster "MCT"?), as of August 2016:
- Is it still made in Sweden? I contacted Waytek but haven't received a response yet.
- Are the dies accurate and durable? They are expensive, I've seen them sold for $40-$111.
You're welcome.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
1. Yes, the Waytek 560 is a rebranded Pressmaster MCT.
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
2. The frame is still made in Sweden. According to the US support personnel I spoke with, they do the final machining/grinding in Sweden, but the castings can come from multiple sources, including Taiwan (gave me the impression most of their castings have been shifted to Taiwan). So they're accurate as a general rule.
That said however, I have had issues with the insulated die for red & blue terminals, as the red side's compliance markings don't fully form on both the original I received as well as it's replacement (Taiwanese casting). The crimps themselves are within spec (Go/No Go + wire pull tests). But as I also have a Panduit CT-1550, it's not a big concern in my case (covered for compliance issues).
I'm pretty precise and don't need the tool to do the work for me. What the tool does have to do, if I understand crimping, is: Be accurate (in this case the die machining?), apply enough force to cause the proper "Cold Weld", and not fall apart due to use. Have you any experience with the "MCT" model by chance?
I own an MCT, and it definitely generates sufficient force to produce a proper cold weld (10,000N/~2250lbs, which is higher than a lot of other makes & models). The dies are properly machined IME as well (have met Go/No Go specs from the terminal manufacturer).
BTW, on a minor note and just for the heck of it, what do you think of those hammer crimers
for large terminals? I tried it out on some 6AWG welding wire and a ring terminal, dremeled it apart to take a look.. idk. It is said that a "cold weld" fuses the wire strands and terminal together like a solid piece. How much of an exaggeration is that? Ever dissected/teardown a good crimp before? Any pics?
Never used one, so I can't say one way or the other. But personally, I'm wary of them given the surface area doesn't keep the entire terminal captive (looks like the terminal could spread, thus not create a proper cold weld).
As per the wire & terminal effectively becoming a single solid mass of metal is entirely correct. You can see some gaps in some cases due to the wire strand size (i.e. stranded structural wire say no bigger than 2/0). But they do actually weld where they come in contact with one another and the terminal surface (gaps are also smaller than what they were originally, as the wire strands deform & fill most of the space). On finely stranded wire, it's truly a solid piece. See photos below.
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
BTW, for non-insulated & insulated terminals that have seams in the crimped section, I'd suggest getting a brazed or welded seam as they can't spread, unlike the cheaper butted seam versions.
![](http://www.etco.com/wp-content/uploads/2012/03/e81fd2e62a.jpg)
![](http://www.aeroelectric.com/Pictures/Terminals/Crimp_Cross-section.jpg)
Wezag has a number of interchangeable systems. It also has a system with two handle styles (CS30 or CK100) that use the same dies.
Thanks.
Had a total brain fart on this one.
