Author Topic: Weller Wx1012 US model in Europe  (Read 3512 times)
Offline FonnesbekTopic starter
« on: October 23, 2013, 11:47:01 am »
Hi is there someone who has the weller wx soldering station who can check if the transformer has a 240volt primary winding, so it can be used in Europe ?
Thanks
Fonnesbek
Offline nanofrog
Re: Weller Wx1012 US model in Europe
« Reply #1 on: October 23, 2013, 06:28:22 pm »
I've never seen Weller use multiple primaries to handle different voltage standards (they've all been region specific, so the transformer would have to be swapped).
That said, is there a particular reason you're not able/willing to use a suitably sized step down transformer to get it to work?
I ask, as a 300W step down isn't that expensive.  :-//
« Reply #2 on: October 25, 2013, 08:34:50 am »
Thanks but I was hoping to avoid a step down
Offline nanofrog
« Reply #3 on: October 25, 2013, 04:32:10 pm »
You could try and replace the transformer in the unit, but I'm not sure if that will be cost effective. I suspect the step-down would be both easier and less expensive, particularly if you get the replacement transformer from Weller (not exactly inexpensive on replacement parts these days).
Maybe put the step-down on a shelf or the floor to save from using bench space?
Offline Kjelt
« Reply #4 on: October 25, 2013, 05:44:53 pm »
If they have normal transformers , then buy two units and put them in series. If thats too expensive buy one in your local shop.
Offline nanofrog
« Reply #5 on: October 25, 2013, 06:57:43 pm »
Sadly it wouldn't fit, as it's just too tight in there. WX series uses a toroidal transformer, and there's a board directly on top of ~ 1/3 of it. Second board is attached to the interface that makes up the front panel.
About 1:50 into the video and you'll see what I mean.
Offline Kjelt
« Reply #6 on: October 26, 2013, 06:15:51 pm »
That's not what I meant, I meant he should buy two Weller 115V stations and put those in series  ;)
