Author Topic: Warning to JBC DDE-1C Soldering Station Owners Check Your Firmware! Teardown Vid  (Read 23929 times)
Offline Horst Zimmermann
 :-// I don´t know what happened but today i was able to update the Firmware of my JBC DDE-2C from version 8886566 to 8886875 which is the latest firmware on the JBC server
2037164-0
what i did:
i downloaded a fresh copy of the firmware from JBC, unzipped it on the USB stick that i have been using before (so no new USB Stick i already tried 9 different sticks) and plugged it in to my station.
The station then showed Reading pendrive. Wait.. then i got a phone call and was about 10-15 minutes away, when i came back i started the firmware upgrade and this time it worked.
I really don´t know why it worked this time, the only two things i can imagine is either the station need more time to read the USB stick or they maybe changed the firmware on the server
EDIT:
I checked the Firmware file and it is the same i downloaded 2 weeks ago, so no change from JBC
I checked the menu of my station, no downgraded functionality all features are there
I feel so dumb right now :-DD
« Last Edit: February 26, 2024, 11:26:06 am by Horst Zimmermann »
Offline KG7AMVTopic starter
  • Rhine_Labs
    • My Personal Blog
That is fantastic, Wonder what changed?
Offline McCarthy
I called JBC USA about 2 months ago and told the guy that I'm about to buy a DDE kit worth 2.5k but don't want to run into ANY issues. He immediately knew about the YT video and case. He told me that that current versions don't have issues, so I bought mine through Tequipment.
Been using it for 2 month with no issues. Best station / system yet, coming from Weller (and I tried the newest smart station too).
Didn't upgrade or look into it, since I just need this thing to work for GPU repairs.
  • Rhine_Labs
    • My Personal Blog
Be sure to run it thru every feature and make sure.
did buy another DDE-2C in the kit with the desoldering tool
i did upgrade my old and the new one to firmware 886887 without any problems
you can clearly see the difference of the screens, the top one is from july 2021 and the bottom from may 2024
the top one (old) looks more washed out and the bottom (new) looks more crisp
2173711-0
« Last Edit: May 08, 2024, 07:53:14 am by Horst Zimmermann »
