Author Topic: Wanted: the Ultimate Multimeter for Electricians and Technicians.  (Read 18104 times)
Offline vk6zgo
Re: Wanted: the Ultimate Multimeter for Electricians and Technicians.
« Reply #25 on: August 09, 2016, 02:50:29 pm »
We had a Fluke 8020B at the transmitter site & it was a pig to use.
The side pushbuttons were hard to operate one handed.
Later,everybody got Fluke 77s in their kit,which,with the offset rotary knob ,were a dream to operate one-handed.
The auto-off on the 77 would not operate if you were actually taking measurements,whereas some later meters quite happily turn the thing off,just as you get set to take a reading.
Another delight I ran into with some early UNI-T meters is that,long before the "low-battery" symbol came up,they started to give nonsense readings on the Resistance range.
That is definitely not a feature you want in your proposed meter!
Offline GalenboTopic starter
« Reply #26 on: August 11, 2016, 08:54:43 am »
In this case that meter has to either not have current measurement or have it clamp only. I've seen tons of hardware store-bought multimeters killed by measuring current of wall socket or car battery. Most non-EE savvy people don't understand how measuring current works and short out first voltage source they find.
True, a multimeter without Amps measurement has it's advantages, even for experienced technicians who know what it's all about.
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Offline Lomax
  • Country: eu
  • Minimalist
« Reply #28 on: October 24, 2016, 02:49:41 pm »
Grrr still that rotation knob...
How about this one, from venerable German Testo:
The following users thanked this post: Galenbo
Online RoGeorge
« Reply #29 on: October 24, 2016, 04:02:05 pm »
This one was can be hang from a belt, also it has push buttons:
Offline Lomax
  • Country: eu
  • Minimalist
« Reply #30 on: October 24, 2016, 04:33:09 pm »
That is one beautiful multimeter! But £600? Just a little outside most people's budget. Then again, I guess you get what you pay for, to some extent - and it is manufactured in Europe.
« Reply #31 on: December 06, 2016, 03:55:06 pm »
Not bad at all, but it costs 150 euro...
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #32 on: December 08, 2016, 08:49:06 pm »
Like many others I do like the look of the Testo meters but they are rather expensive down here, anyway it would appear that they may be prone to magnetic fields according to this recently uploaded video, I'm yet to own one.   :-DMM :-BROKE :palm:
Offline M. András
  • Country: hu
« Reply #33 on: December 18, 2016, 08:46:45 am »
i do own the 770-3 model its their clamp meter, im statisfied with the tool for daily use as an electrician, the lcd does not like cold at all apart from that i didnt find any problems with it so far, its expensive but you cant deny the innovation of their automatic function sensing feature, and you can hold these in relatively small hands with ease and still be on the safe side of the engineering of the meters unlike most chinese ones, pretty labels and such but i would not trust my life with it
Offline salbayeng
« Reply #34 on: December 19, 2016, 05:25:56 am »
GalenBo ,
I do sympathise with your desire for knobless meters,  the only pushbutton meter I have is a smd tweezer meter.
There was a nice meter made by Philips? years ago with some sliders that were easily moved with your thumb.
Another useful feature (missing on your "ideal" multimeter) is having the volts and common spaced 19.4mm apart, then you can plug in a double prong banana plug.  Or a shunt with a 1.000ohm resistor , some back/back diodes and a 470uF capacitor  (this gives a better result measuring mA).
Online RAPo
« Reply #35 on: May 06, 2024, 05:01:14 pm »
Yep, I have the 760-2. A very nice meter.
