I am looking for a microscope for rework in a professional lab environment, I can spend around 2000 EUR for it.
Most importantly I would need a working distance of at least 200mm, better 250mm. I almost exclusively work on heavy copper PCBs (6 layers 2oz etc.) and often solder them preheated on a hot plate which already consumes 100mm of the working distance.
EDIT: I might have chosen some incorrect vocabulary here. The
optical working distance would be fine at 100mm to 150mm, but the stand (
mechanical working distance, if you want) needs to be able to accommodate for the distance consumed by the hot plate arrangement.
Further points:
- boom stand
- magnification and zoom for wide range of component sizes from 0402 to TQFP-144
- trinocular with cam would be highly preferred, but not mandatory
- available to buy in Europe
Could somebody recommend anything?
