Doesn't appear to be!
According to the post a bit above, I shouldn't have to change the kernel?
Thanks for any help!
This is the output when i run make install:
pi@raspberrypi:~/linux-gpib/linux-gpib-code/linux-gpib-user $ sudo make install
Making install in include
make[1]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include'
Making install in gpib
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include/gpib'
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include/gpib'
make[3]: Nothing to be done for 'install-exec-am'.
/bin/mkdir -p '/usr/local/include/gpib'
/usr/bin/install -c -m 644 gpib_user.h ib.h '/usr/local/include/gpib'
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include/gpib'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include/gpib'
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include'
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include'
make[3]: Nothing to be done for 'install-data-am'.
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include'
make[1]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/include'
Making install in lib
make[1]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib'
make install-recursive
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib'
Making install in .
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib'
make[4]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib'
/bin/mkdir -p '/usr/local/lib'
/bin/bash ../libtool --mode=install /usr/bin/install -c libgpib.la '/usr/local/lib'
libtool: install: /usr/bin/install -c .libs/libgpib.so.0.3.0 /usr/local/lib/libgpib.so.0.3.0
libtool: install: (cd /usr/local/lib && { ln -s -f libgpib.so.0.3.0 libgpib.so.0 || { rm -f libgpib.so.0 && ln -s libgpib.so.0.3.0 libgpib.so.0; }; })
libtool: install: (cd /usr/local/lib && { ln -s -f libgpib.so.0.3.0 libgpib.so || { rm -f libgpib.so && ln -s libgpib.so.0.3.0 libgpib.so; }; })
libtool: install: /usr/bin/install -c .libs/libgpib.lai /usr/local/lib/libgpib.la
libtool: finish: PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/sbin" ldconfig -n /usr/local/lib
Libraries have been installed in:
/usr/local/lib
If you ever happen to want to link against installed libraries
in a given directory, LIBDIR, you must either use libtool, and
specify the full pathname of the library, or use the '-LLIBDIR'
flag during linking and do at least one of the following:
- add LIBDIR to the 'LD_LIBRARY_PATH' environment variable
during execution
- add LIBDIR to the 'LD_RUN_PATH' environment variable
during linking
- use the '-Wl,-rpath -Wl,LIBDIR' linker flag
- have your system administrator add LIBDIR to '/etc/ld.so.conf'
See any operating system documentation about shared libraries for
more information, such as the ld(1) and ld.so(8) manual pages.
/bin/mkdir -p '/usr/local/lib/pkgconfig'
/usr/bin/install -c -m 644 libgpib.pc '/usr/local/lib/pkgconfig'
make[4]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib'
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib'
Making install in gpib_config
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib/gpib_config'
make[4]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib/gpib_config'
/bin/mkdir -p '/usr/local/sbin'
/bin/bash ../../libtool --mode=install /usr/bin/install -c gpib_config '/usr/local/sbin'
libtool: install: /usr/bin/install -c .libs/gpib_config /usr/local/sbin/gpib_config
make[4]: Nothing to be done for 'install-data-am'.
make[4]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib/gpib_config'
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib/gpib_config'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib'
make[1]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/lib'
Making install in drivers
make[1]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/drivers'
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/drivers'
make[2]: Nothing to be done for 'install-exec-am'.
make install-data-hook
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/drivers'
test -e /usr/local/etc/gpib.conf || \
/usr/bin/install -c -m 644 -D ../util/templates/gpib.conf /usr/local/etc/gpib.conf
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/drivers'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/drivers'
make[1]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/drivers'
Making install in examples
make[1]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/examples'
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/examples'
/bin/mkdir -p '/usr/local/bin'
/bin/bash ../libtool --mode=install /usr/bin/install -c ibtest ibterm '/usr/local/bin'
libtool: install: /usr/bin/install -c .libs/ibtest /usr/local/bin/ibtest
libtool: install: /usr/bin/install -c .libs/ibterm /usr/local/bin/ibterm
make[2]: Nothing to be done for 'install-data-am'.
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/examples'
make[1]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/examples'
Making install in test
make[1]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/test'
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/test'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/test'
make[1]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/test'
Making install in doc
make[1]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/doc'
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/doc'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/doc'
make[1]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/doc'
Making install in language
make[1]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language'
Making install in python
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language/python'
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language/python'
/usr/bin/python setup.py install --prefix=/usr/local
running install
running build
running build_py
running build_ext
running install_lib
copying build/lib.linux-armv7l-2.7/Gpib.py -> /usr/local/lib/python2.7/dist-packages
copying build/lib.linux-armv7l-2.7/gpib.so -> /usr/local/lib/python2.7/dist-packages
byte-compiling /usr/local/lib/python2.7/dist-packages/Gpib.py to Gpib.pyc
running install_egg_info
Writing /usr/local/lib/python2.7/dist-packages/gpib-1.0-py2.7.egg-info
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language/python'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language/python'
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language'
make -C perl all
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language/perl'
Running Mkbootstrap for LinuxGpib ()
chmod 644 "LinuxGpib.bs"
Manifying 1 pod document
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language/perl'
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language'
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language'
make[1]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/language'
Making install in usb
make[1]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb'
Making install in agilent_82357a
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb/agilent_82357a'
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb/agilent_82357a'
/bin/sed -e 's,[@]sbindir[@],/usr/local/sbin,g' -e 's,[@]datadir[@],/usr/local/share,g' -e 's,[@]hotplug_usb_conf_dir[@],/usr/local/etc/hotplug/usb,g' < ./99-agilent_82357a.rules.in >99-agilent_82357a.rules
/bin/sed -e 's,[@]sbindir[@],/usr/local/sbin,g' -e 's,[@]datadir[@],/usr/local/share,g' -e 's,[@]hotplug_usb_conf_dir[@],/usr/local/etc/hotplug/usb,g' < ./agilent_82357a.in >agilent_82357a
test -e /usr/local/etc/hotplug/usb/agilent_82357a ||\
/usr/bin/install -c -D agilent_82357a /usr/local/etc/hotplug/usb/agilent_82357a
test -e /usr/local/etc/hotplug/usb/agilent_82357a.usermap ||\
/usr/bin/install -c -m 644 -D ./agilent_82357a.usermap /usr/local/etc/hotplug/usb/agilent_82357a.usermap
/usr/bin/install -c -d /usr/local/share/usb/agilent_82357a
test -d /usr/local/etc/udev/rules.d && test -e /usr/local/etc/udev/rules.d/99-agilent_82357a.rules ||\
/usr/bin/install -c -m 644 -D 99-agilent_82357a.rules /usr/local/etc/udev/rules.d/99-agilent_82357a.rules
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb/agilent_82357a'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb/agilent_82357a'
Making install in ni_usb_gpib
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb/ni_usb_gpib'
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb/ni_usb_gpib'
/bin/sed -e 's,[@]sbindir[@],/usr/local/sbin,g' -e 's,[@]datadir[@],/usr/local/share,g' -e 's,[@]hotplug_usb_conf_dir[@],/usr/local/etc/hotplug/usb,g' < ./99-ni_usb_gpib.rules.in >99-ni_usb_gpib.rules
/bin/sed -e 's,[@]sbindir[@],/usr/local/sbin,g' -e 's,[@]datadir[@],/usr/local/share,g' -e 's,[@]hotplug_usb_conf_dir[@],/usr/local/etc/hotplug/usb,g' < ./ni_usb_gpib.in >ni_usb_gpib
test -e /usr/local/etc/hotplug/usb/ni_usb_gpib ||\
/usr/bin/install -c -D ni_usb_gpib /usr/local/etc/hotplug/usb/ni_usb_gpib
test -e /usr/local/etc/hotplug/usb/ni_usb_gpib.usermap ||\
/usr/bin/install -c -m 644 -D ./ni_usb_gpib.usermap /usr/local/etc/hotplug/usb/ni_usb_gpib.usermap
/usr/bin/install -c -d /usr/local/share/usb/ni_usb_gpib
test -d /usr/local/etc/udev/rules.d && test -e /usr/local/etc/udev/rules.d/99-ni_usb_gpib.rules ||\
/usr/bin/install -c -m 644 -D 99-ni_usb_gpib.rules /usr/local/etc/udev/rules.d/99-ni_usb_gpib.rules
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb/ni_usb_gpib'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb/ni_usb_gpib'
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb'
make[3]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb'
test -d /usr/local/etc/udev/rules.d && test -e /usr/local/etc/udev/rules.d/99-gpib-generic.rules ||\
/usr/bin/install -c -m 644 -D ./99-gpib-generic.rules /usr/local/etc/udev/rules.d/99-gpib-generic.rules
make[3]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb'
make[1]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user/usb'
make[1]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user'
make[2]: Entering directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user'
make[2]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user'
make[1]: Leaving directory '/home/pi/linux-gpib/linux-gpib-code/linux-gpib-user'
