Several years ago I bought a Tektronix DSA602A digitizing signal analyzer with plugins. It is a very interesting piece of test equipment but what caught my eye are the plugins it came with. Particularly the 11A71 plugin.
There seems to be quite a lack of pictures of the Tek 11000 series scopes so I hope these pictures will be interesting to someone.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07374.jpg)
The plugins are exactly the same size as the Tek 7000 series, but can not be physically pushed into the connector.
Although 7000 series plugins can easily be converted to fit 11000 series mainframes.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07378.jpg)
Right side of the 11A71 plugin. This board is all analog.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07379.jpg)
Here the loop of cable can be seen which acts as a delay line to compensate for skew between various amplifiers.
It connects to the input attenuator.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07380.jpg)
Closeup of the input attenuator. The thick film resistors can be seen. All are laser trimmed. There is also a capacitor which is switched in when AC coupling is selected. The signal path is 50 ohm.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07381.jpg)
The attenuated signal then connects to the first hybrid IC (the brown one) which serves as input protection. The signal is then converted from single ended to differential by the first white IC and then the various gain and compensation stages follow. The signal path is entirely differential up to the AD converter in the mainframe.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07382.jpg)
Various compensation trimpots
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07391.jpg)
Closeup of the HF design used back in the late 80's
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07390.jpg)
On the left side of the plugin is the digital section that communicates with the mainframe
Very retro design. I just hope the battery in the Dallas non volatile RAM doesn't run out any time soon.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07394.jpg)
Closeup of the daughter board. Looks like standard 7400 series logic and TL074 quad opamps.
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07395.jpg)
Now for some fun:
I sat down and stared for several minutes at the plugin and the specs labeled on the front
![](http://i1138.photobucket.com/albums/n537/tekscopes/DSC07376.jpg)
Then I realized
![](http://i1138.photobucket.com/albums/n537/tekscopes/TekNaziAmp.jpg)
Looking closely at the hybrid ICs
![](http://i1138.photobucket.com/albums/n537/tekscopes/TekSwas.jpg)
I don't know if this is a real easter egg or not but I find it funny nonetheless.
