Author Topic: Teardown: Philips SX1019 LNB  (Read 9593 times)
Offline wkbTopic starter
« on: March 17, 2012, 07:59:03 pm »
Today I spent EUR 2 on a surplus LNB for DVB-S reception.  Although I know how they work I had never seen one 'dissected'. So...
The type is a Philips SX1019.  The grey circular 'pills' are the 2 local oscillators, one for high and one for low band reception.
The bottom view of the cast aluminium body shows 2 Torx-head screws to tune these oscillators (they are closest to the F-connector).  The gold plated pins in a white Teflon washer are for horizontally and vertically polarised signals.  2 FETs are used to select one or the other.  Lots of microstrip 'components' too.
Online NiHaoMike
    • Facebook Page
Re: Teardown: Philips SX1019 LNB
« Reply #1 on: March 18, 2012, 02:33:51 am »
Jeri Ellsworth shows how to build a radar from old satellite dishes:
« Reply #2 on: March 18, 2012, 11:59:39 am »
I took some more pictures, the second one nicely shows the horizontal and vertical 'pickups'
« Last Edit: March 21, 2012, 08:23:32 pm by wkb »
Offline amyk
« Reply #3 on: March 19, 2012, 11:57:13 am »
Always interesting to look at microwave stuff because of how different things are. Most people who are otherwise knowledgeable in lower-frequency electronics would not easily see how a ceramic puck next to a few PCB traces is enough to form an oscillator.
« Reply #4 on: March 21, 2012, 12:25:22 pm »
Microwaves - where electronics becomes plumbing. Or rather, where most of your parts come from the hardware shop, and are assembled with a gas torch.
