Author Topic: Upgrade from Metcal SP-200  (Read 196 times)
Offline EverbraveTopic starter
« on: August 19, 2024, 10:36:28 am »
The questions I’m asking myself and seeking your opinion to answer are:
1) what is the upgrade path from Metcal SP-200 for a hobbyist, the PS-900 or the MFR-series?
2) Will I notice the upgrade to the higher power?
3) Is an upgrade necessary at all?
What do you think?
Thanks
Offline thm_w
  • Non-expert
Re: Upgrade from Metcal SP-200
« Reply #1 on: August 19, 2024, 09:20:51 pm »
I think we already discussed in your other thread: https://www.eevblog.com/forum/reviews/metcal-gt-90120-is-still-a-metcal/
Go plug in a watt meter and start soldering stuff you normally solder. If you don't max out the input (60W in? somewhere around there), then you won't notice a significant difference in performance.
Of course, power will always max out when turning on, so heat up time will be a bit faster.
https://www.reddit.com/r/AskElectronics/comments/531rf0/looking_to_buy_a_metcal_any_opinions/
https://www.ellsworth.com/globalassets/literature-library/manufacturer/oki/oki-product-guide-hand-soldering-and-rework-ps-900-and-mfr-series.pdf?srsltid=AfmBOooHyfVsnPXbCjfMIhF5dHxwGoegk8qtJUsvuJa-pjrLwUjZdYs7
« Reply #2 on: August 19, 2024, 10:48:21 pm »
I get that regarding power; any thoughts regarding ps-900 vs. Mfr?
Thanks
