If anybody has advice on using it, it would be much appreciated.
Maybe this transformer could be usable
It is strange that, there is no huge fans inside and airflow holse in enclosure?
Anyway, It is interesting if this thick strand wires are... really copper wires or... plated aluminium, which I've found in one of the China MOTs
If primary winding has desetn quality, I'd checked secondary windings and maybe replaced with custom few turns of thick strand copper wires and replaced transformer primary controll circuit with own SCR's and small MPU, so than it souldn't be a problem to... melt thin copper wires like 2.5mm2 in my custom made spot welder, controlled by ATTiny85 and two SCR's in antiparallel on trafo primary
I've used Hall effect current sensor on this huge trafo primary to controll phase angle when running this thing at full mains wave lenghts 20ms @ 50Hz 230VAC is too much power, so MPU on two ADCs is looking for potentiometers settings of power setting potentiometer and another which allows set total pulse time between 20ms pulse up to 10seconds in 20ms (@50Hz) multimply to let transformer operate always at full wavelenghts at high power
