Here are the units proudly sitting on the bench. I like the units because they are very small, compact and have quality feeling. Case of units is made from plastics and they have a rubber case with a stand in the back. The units work very good, i was impressed by ESR meter performance. It measured good known good capacitors and in a moment catches known bad capacitors.
The only thing i don't like that leads of ESR meter are hard soldered to the unit and do not use a connector. Since this are so simply units i don't know what to review more
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
The funny fact : The capacitor decade fell to bits when i removed rubber case, it looks like Chinese forget to put screws. It can clearly be seen the casing never seen a self tapping screw
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
