Hello David! I installed firmware 1.13.8 on my stations, everything works fine! It’s very good that the choice of station operating mode in the menu is back, it was sorely missed! In my plans I want to assemble a station that operates in two modes - c245 and t12, that is, at the station itself it will be possible to connect both handles, and the choice of operating mode will be carried out in the menu. From this I have a question - saving the calibration data of the tips will only be for one mode or will it be for both?
P.S. Maybe you remember I once complained to you about the fact that my battery was draining very quickly and that the new firmware version was not always installed correctly? The problem was solved by replacing the bluepill board on my custom station with a board with the original chip and everything worked like a Swiss watch! Also, at a sale on Aliexpress in the official ksger store, I finally bought myself a T12 station version 2.1 with an LED display (replaced the display with a white one, installed a mercury bibrosensor in the handle and installed an LED to indicate the operation of the handle) and, of course, immediately installed your firmware during installation There were no problems, everything works great!
