Ok, thanks! That's my main worry: the cheap handles shorting causing the transistor to blow, or just something random shorting out.
Seems to be a regular occurrence with these stations.
I'm definitely avoiding the metal handles yeah. Besides heating up it would also kinda seem like a safety hazard to me to use those, especially with these stations.
Mainly looking at the 907 and 9051. The 907 is very chunky though and also seems to short out for many people, and the 9051 tends to melt and break.
The Yihua is a different station all together. The handle seems more robust. It's thinner and at least 2-3cm shorter from tip to fingers as on the 907, but the tip protrudes out more as on the 9051 and others, making it more likely that it'll handle the heat. Also the brand's products are certified by 3C, CE, UL, SGS, and ROHS. That's why I'm kinda leaning towards that one.
It has way less features though. For example it doesn't have per-tip calibration. But then again, how important is this?
The Sequre is a different station too. Not much to find about it though (only video is from 8 days ago, by learnelectronics; there's a few vids on the mini model) . The brand seems pretty new too; but they are certified by CE, FC, and ROHS, and from what I can find, they seem to make some decent stuff. Here the tip protrudes out about the same as with the Yihua, so shouldn't have any issues with heat at least (made from aluminium though so that's one small downside). The tip doesn't slide in as with the KSGER type stations, but clicks in. It's also a little more feature-rich than the Yihua. No per-tip calibration though but should have auto-calibration (which I don't know how, and how well, it would work though).
All the T12 type stations are about the same price. The only obviously cheaper ones are from Handskit (
https://a.aliexpress.com/_EjwauOT), but the KSGERs and Quecoos seem better to me, and the price doesn't differ a lot either.
I don't know if the Handskit handles are any better when it comes to shorting out and heat-management?
The Oss T12-X also has a different handle (which again, I don't know if it has the same issues with shorting out and heat):
https://a.aliexpress.com/_EHctfqRThe current prices (all including 3 tips; I'll probably order with just one though and buy real tips instead, but just to make the comparison easier):
KSGER V2.3: €67,7
KSGER V2.1: €65
Quecoo 958: €72
Quecoo 955: €62
Yihua 948DB+ II: €62 (also includes a stand that would cost me €10)
Sequre MSS12 Pro: €83 (with just one tip)
Handskit T12: €53,6 (including €10 stand)
Oss T12-X: €69,30 (including €10 stand)
