Thanks for reporting. The projects is almost stalled since I'm getting little to none feedback.
Testing every combination myself would take a lot of time, not realistic...
If anyone with a STM32F072 allows me to remotely debug the code, trying to find the current issue with it, would be nice!
AndyC, not a bug, it's intentional to make these people life's harder, that's my xenophobia kicking in
Confirmed here, so strange the language affects the program behaviour, shouldn't at all, it's just an array of text strings
Will check it!
Edit:I think I got it. It worked removing optimizations, so it had to be some undefined behavior.
The reserved char array for the zero string was 16 bytes long because I thought is as normal ASCII, forgetting special chars use 2 bytes (unicode/UTF-8), so it was overflowing and writing over other variables.
Edit2:
v1.02 Released. Should be working now.
