Author Topic: CFW for KSGER/Quicko STM32 Soldering Stations  (Read 874287 times)
marck120 and 18 Guests are viewing this topic.
Offline bozo
  • Country: hr
Re: CFW for KSGER/Quicko STM32 Soldering Stations
« Reply #2900 on: May 01, 2022, 11:13:04 am »
All updates for SSD1309 (V2.0) and ST7565 (V3.0) work.
Offline AUTOMOTIVE SOLUTIONS
« Reply #2901 on: May 01, 2022, 01:29:59 pm »
DavidAlfa hi sorry i hadn't tested new build  |O
i really like the new layout of  build script.
let me know if you need me to test any versions (still glued to the bench)
bozo just idea could you put both screen's connectors so layout will let you use any screen? SSD1309/ ST7565
« Last Edit: May 01, 2022, 01:43:30 pm by AUTOMOTIVE SOLUTIONS »
Offline KocsisV
  • Country: hu
« Reply #2902 on: May 01, 2022, 08:16:41 pm »
IRON is 2KB, and most remaining screens use ~1KB or less.
That is great, so there is plenty of room left, even on 10k targets!
Nevermind: STM32F101/2/3 don't have USB OTG, so it's a dead end!
One can implement one in software ;) . I'm leaning towards the printout method via the virtual serial port over SWD. Or just reading out the flash completely and parsing it back via a tool (this is what I did previously). And thanks ST for implementing the standard CRC32 with the Ethernet polinom with a non standard implementation!... Took me 2+hour too figure out what magic combination of byte ordering, data inversion works. At least on the newer controllers the reversing and negating can be controlled, but not on the F1xx.
« Last Edit: May 01, 2022, 08:18:32 pm by KocsisV »
The following users thanked this post: AUTOMOTIVE SOLUTIONS
« Reply #2903 on: May 01, 2022, 11:45:50 pm »
KocsisV thanks you for helping on the eev
sorry to be a Pain but do you think its posable for me to add second input like stand sleep mode but in ide to sleep and switch mosfet off until it reads there is a valid tip temp input so i can just swap tips without switching off the unit (similar tips) thanks andy
Offline wickated
  • Country: ru
« Reply #2904 on: May 02, 2022, 02:08:55 am »
you can hotswap tips
Offline DavidAlfa
« Reply #2905 on: May 02, 2022, 04:13:28 am »
Do you have a lot of free time, don't you? :D
AUTOMOTIVE, if the station does weird things when removing the tip, just solder a 1M resistor between 3.3V and T12+ (Or 10M between the mosfet power pins), it will keep the amplifier input at high level removing any bouncing, and it won't affect the measurement on normal operation.
« Last Edit: May 02, 2022, 05:47:01 am by DavidAlfa »
« Reply #2906 on: May 02, 2022, 02:00:04 pm »
thanks David was trying not to bother you .i was thinking trying to adding tip changing input like jbc. but if i can just change tips with out frying anything then not needed?
thanks wickated i didn't know ok to hot swap
(working on pcb layout)
« Last Edit: May 02, 2022, 02:04:45 pm by AUTOMOTIVE SOLUTIONS »
Offline DavidAlfa
« Reply #2907 on: May 02, 2022, 03:39:37 pm »
Remember the power is the upper T12 pin, thus the last to make contact when inserting it.
Only a faulty connection could cause issues, ex. a bent contact or broken wire shorting the power, in that case it will blow the mosfet with or without detection pin, so no difference.
Offline wickated
  • Country: ru
« Reply #2908 on: May 02, 2022, 03:43:29 pm »
if you want jbc experinec while tip swap u can select "run after error" mode to "off". so after tip change u have to manually start.
Offline DavidAlfa
« Reply #2909 on: May 02, 2022, 04:10:05 pm »
Or just increase the error timeout.
« Reply #2910 on: May 02, 2022, 11:42:40 pm »
thanks all two ways to skin a cat  :-//
Offline bozo
  • Country: hr
« Reply #2911 on: May 03, 2022, 06:22:20 pm »
Test with SSD1309 SPI KSGER V3.0 works well.
The following users thanked this post: DavidAlfa
« Reply #2912 on: May 03, 2022, 09:24:06 pm »
what was the problem?
Offline KocsisV
  • Country: hu
« Reply #2913 on: May 05, 2022, 09:11:08 pm »
Why does the latest STM32CubeIde ships with an 8 year old version of make... it does not support grouped targets. For that a more recent version is required (4.3 released in 2020 january).
I'm trying to get rid of the need to manually generate code from the .ioc files and also have only one main.c/.h (not one per board).
Offline soldermarc
« Reply #2914 on: May 06, 2022, 11:18:25 am »
Which hardware revision should be preferred for building a T12 STM32 station with custom firmware and maybe display upgrade in mind?
As far as I found a spi interface is needed.
It is hard to find a seller making right descriptions, even the STM32 clones are only mentioned sometimes. And if you can trust the pictures...  :-//
At the moment there are versions named 2.1, 2.1s, 3.1s . I also found a version called 2.01 that seems to have the spi, but also the not(?) cfw compatible mm32.
https://www.aliexpress.com/item/4000104741034.html
Offline DavidAlfa
« Reply #2915 on: May 06, 2022, 12:32:18 pm »
It's hard to guess. Neither I have too clear the KSGER versions.
But basically: 4 pin OLED=i2c,  6-7pin=SPI.
Most OLEDs (SH1106, SSD1306, SSD1309) can be configured to work in i2c by changing some resistors.
It's only the cheaper alternative ST7565 LCD which can only work in SPI mode.
Cheapest STM32 station I've found so far.
i2c display, fancy aluminium plate, nice handle, but linear regulator (might run hot), although I don't think it'll overload:
https://www.aliexpress.com/item/4000183089084.html
More updated hw, no overheating issues, etc (i2c display)
I'd get this one. i2c isn't really a problem, unless you specifically want to connect a ST7565 display.
https://www.aliexpress.com/item/1005003108002691.html
Older Quicko design, terrible fw but decent hw (SPI display):
https://www.aliexpress.com/item/4000611002273.html
Then you enter overpriced KSGER territory, prices double very fast and doesn't really provide any hw enhancements!
In any case, ask the seller first to confirm it ships with stm32 and not some random clone!
« Last Edit: May 07, 2022, 07:16:52 pm by DavidAlfa »
Offline ygi
« Reply #2916 on: May 06, 2022, 01:30:12 pm »
Though if you're going to install one of those "big" 2.42" screens, it won't fit inside the original enclosure. It might be a better deal to just buy board and PSU separately and then find or make a custom case.
I spent some time looking for a bigger screen that would fit the original case but for anything bigger than 1.3", the frame and/or driver board are too tall. Meh, 1.3" is good enough anyway.
Offline soldermarc
« Reply #2917 on: May 06, 2022, 01:46:44 pm »
@DavidAlfa
Wow, thank you very much! That helps a lot.
The second one mentions a CKS controller chip
Due to the impact of covid-19, the STM32 chip is out of stock, and the STM32 chip is temporarily replaced with a CKS microcontroller. The recovery time is temporarily uncertain.
Whatever "recovery time" should mean?
@ygi
Yes, I already thought about this. I could build a soldering station (or maybe two) around one bigger PSU I already have.
Main problem is, most combinations of board+handle+tips bought separately are more expensive than a complete station. Even if I throw away the original PSU and case. :(
You think the option for a bigger display isn't worth the expense and extra costs?
Edit: I thought, it would be nice to have a slightly bigger display, maybe LCD, that has no OLED disadvantages and lasts as long as the rest of my soldering career...
« Last Edit: May 06, 2022, 01:50:24 pm by soldermarc »
Offline ygi
« Reply #2918 on: May 06, 2022, 02:39:57 pm »
To me it's not worth it because I don't enjoy building the case and I'm not confident I can make it look as nice as I'd want, I also like the stock form factor and looks and my eyes are still good enough to read what's on the small screen.
That being said I can't speak for you. I don't know about your needs, what you deem important from the usability standpoint or how much work you're willing to put into this project. What I can tell is my station is now 5 years old and its tiny (0.96") OLED screen still works fine and bright. I do have a 1.3" on order just because it's a cheap and easy improvement.
The following users thanked this post: soldermarc
Offline DavidAlfa
« Reply #2919 on: May 06, 2022, 08:36:58 pm »
So the recent planetary conjuction did the magic and I finally received the screen.
Worked right away with the current settings.
It's pretty decent, definitely a lot bigger than the 1.3" OLED.
The only real drawback is the extremely slow switching time, it seems the pixel response time is like 300ms, so fast moving images look weird.
The angles aren't terrible either, you have about 45° where the image looks nice, then it starts to wash out.
The background haze can be greatly enhanced with a dark filter (Check picture with the original dark filter on top).
With daylight the contrast is a lot better, it's in the night/afternoon where you notice the black pixels let some light pass through.
The backlight consumes 50-60mA at 3.3V.
Finally, a video in daylight:
« Last Edit: May 07, 2022, 03:01:27 pm by DavidAlfa »
The following users thanked this post: mastershake
Offline mastershake
« Reply #2920 on: May 07, 2022, 04:08:28 am »
im still waiting for mine to arrive i ordered all three colors to see which i like the best then i may order a few more. using the green oled ones now.
Offline yelkvi
  • Country: ru
« Reply #2921 on: May 07, 2022, 04:40:38 am »
Great news! :-+
I just have to wait for my displays to arrive.
I analyzed the circuit with I2C displays. It is easy to modify it for the SPI indicator.
Turning off the display now makes no sense - the current consumption is scanty, the display itself does not degrade (unlike OLED)
You can also make a clock (as in the original firmware) in standby mode
Offline DavidAlfa
« Reply #2922 on: May 07, 2022, 08:00:16 am »
You can't power these down, I mean, you can send the poweroff command, but the backlight will stay lit unless you make some modifications, so the dimming options are removed for this display.
The current consumption is only important for ksgers with linear regulator (Reducing 24V to 3.3V), the display alone would cause a thermal load of 1.2W, which is a lot for a small regulator.
You could connect the leds to 24V with a 2W 330ohm resistor...
« Last Edit: May 07, 2022, 03:25:42 pm by DavidAlfa »
Offline KocsisV
  • Country: hu
« Reply #2923 on: May 08, 2022, 06:51:23 pm »
Do the oled and lcd variants require different IO configuration files?
Offline DavidAlfa
« Reply #2924 on: May 08, 2022, 07:03:12 pm »
The only difference between them is in board.h, having either "#define ST7565" or "#define SSD1306".
I thought the hardware profile would need to be adjusted, perhabs slower SPI clocks, but not required in the end.
I know I could do it better, but it's easier to just copy the entire folder, as I said, I already spent too much time in this project, it works, it's documented, has a idiot-proof building script... what else?  :D
