Both stations are STC based, meaning they aren't compatible with David's firmware.
Quicko's handle isn't that bad, it's serviceable. It's less practical because the locking screw makes it harder to swap tips and it's also less accurate for fine work because the distance from the tip to your fingers is significantly longer. If you've got shaky hands like me when doing very precise work, Handskit handle is a huge help. But sometimes, having a longer tip helps accessing a component between taller components (like heatsink or something). Handskit handle gets uncomfortably hot when in use for over 30min. It's not "burning hot" but still, more heat shielding would be needed.
Finally, when it comes to internal vs external power supply, your tip will most likely not be grounded with an external supply. Sometimes, Chinese manufacturers fail at grounding tip even with internal supply but it's usually easy to fix.
