David, is there a way to sort tips by the name? When I want to pick an inserted tip I need to scroll round to see where it is. Question is in a form if it is possible to please put it on ToDo list
Hmmm. I already had an efficient bubble sort algorithm I made for other project, so it was easy.
Tips will be automatically sorted on any addition/deletion/modification, keeping track of the current tip being used.
I also added a new feature: Now you can also select the working tip from the tip list screen by long-clicking over it.
This make it easier when you have a lot of tips in the system.
Updated builds
Don't know if this has been asked before, but would it be possible to add a pre-compiled list of tips that can enable/disable similar to the original fw?
I don't see much sense on that, and complicates things. There're 40+ T12 types. It's okay as it is.
The purpose of having only one tip by default is to calibrate it, then the new tips will copy that calibration and be more or less close.
I'd add more tips, but it's stupid for a simple reason: You'll have a lot of completely uncalibrated tips, every single one requiring manual calibration.
It's much easier to simply add or copy an exiting calibrated tip and write 4 letters.
Currently, enabling/disabling the tips cannot be easily done. ToDo, maybe in the future.
