Maybe, maybe... Maybe someone could send me $1.000.000
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
It's fine for me, I already said that a thousand times, I'm not doing that, so stop insisting, it's really bad for my patience
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
Wickated, I see, the symbol "Т" was missing from the font script. I'll fix it before the new release. It's a bit messy to do!
Isn't this wrong? Mixing upper and lower case options?
.WakeModes = { "откл", "СОН", "ВЫКЛ", "все" },
I made more changes to the oled dimmer:
[SLP] option has changed to [ON]. So you have [OFF] [ON] [ALL].
ON mode will be applied in low power modes (sleep and standby), no matter the temperature, as the screen is perfectly readable.
The safety is still there, it will only turn off the screen only in sleep mode, when the tip temperature is below 100ºC.
[ALL] is same as before, enabling the dimmer while running (But never turning off).
Feel free to show your suggestions before I make the new builds.
